Outside temperature indicator
I have a new 2015 corvette. I have read the owners manual and cannot find where the outside temperature reading is. I have a 3 LT. I see under weather the inside temperature but cannot find the outside temperature.
Top left of the infotainment screen. (Larry beat me to it)
Discovered when operating in ignition accessory position, the temperature indication will disappear a few minutes prior to time out of the accessory function.
If your not seeing the temp,then you have a bad sensor or wire not connected,somewhere. Trip to dealer for fix.
Unit isn't getting signal. Possible sensor or wiring problem. There is nothing you as operator have to accomplish to view display.
Received 19,309 Likes
'20-'21-'22-'23-'24
