Jacking up the C7
Jacking up the C7
Pardon my ignorance, I have never owned a Corvette before and I understand you need to use jacking pucks to lift the car?
Are these necessary? Where does one place the jack stand after using the pucks?
Thanks for the help
Thanks for the help
Jacking pucks are inserted into the four tie-down slots used for shipping the car. Your can make your own from hockey pucks or buy them from forum vendors. Your manual shows the other recommended support points.
The pucks are not "necessary", you can carefully place the jack on the frame where the tie-downs hook in. Look for a slot in the frame under the door, front and back. Be careful not to place the jack on the rocker panel! You'll crack the panel. Also, there's a chance the jack might slip and crunch the rocker panels, therefore most people buy the pucks. I bought the "stay in place" type so any jack man has them when needed. The jack stands go under the frame as depicted in the owner's manual, no conflict with the jacking pucks.
E-Ray, 3LZ, ZER, LIFT
Received 9,624 Likes
Here's a colored pic I made from one in the current Service Manual. The warning was put in after a poster said he jacked his car up from the front spring and caused it to bend!
GM lifting points. Note for rear and front cradle location you'll need a cross brace if you want to jack directly from the front or rear.
phantasms (04-26-2016)
The red circles are where the jacking pucks go. You can lift the car from the other jacking points, and place jack stands under the pucks. I generally prefer to put the stands under either the green or blue circled areas.
Thanks for the clarification.
Worked on cars with my Dad and he would insist that I hit the jacked up car hard with my shoulder to see if it was safe! He had a friend die when a car fell on him so was always rightfully cautious!
Jack up rear first and put stanchions under the wheels then jack up the front and use jack stands.
Maybe a dumb question. I have jack stands that look like the attached picture. Never used them before on my C7, not sure if I should.
Should I use the low-profile jack on the sides and then place the stands on the green circles?
Looking to do my M7 CAGS eliminator soon.
Jack Stand Pads Avoid Scratching Frame
And if I jack up one side at a time, there's no issue with weight distribution, etc.?
So plan is to use the driver rear jacking puck, place one jack stand underneath, then use the passenger rear jacking puck, and place the second jack stand.
No problem?
No problem?
One other jacking issue. If using a low profile hydraulic jack as you raise the car the jack must slide into the car to keep the jack saddle centered on the jack pad. Be sure it is perpendicular to the car so it can move directly into the car. That is an advantage of a scissor jack, it lifts straight up. It's also less expensive but takes more work.
So to summarize, I install jack pucks in the wholes where the red circles are. Jack car using these as presure points for said jack..
Is there any issue raising one side first? Do you guys/gals place the Jack stands on the green circles or right next to the jack pucks?
