Oil Temperature and Paddle Shifting
Old 06-27-2015, 12:14 AM
Rossi6998
Rossi6998's Avatar
Default Oil Temperature and Paddle Shifting
Today, I was playing around with the paddle shifters and I noticed my oil temperature went up about 15 to 30 degrees in a matter of seconds (maybe 30 seconds). Normally, the oil temperature hovers around 215 degrees. It makes sense the oil would get hotter because you are generally running the engine at higher RPMs while in paddle shifting mode, but it still surprised me.
Has anyone else noticed this?
Old 06-27-2015, 10:43 AM
axr6
axr6's Avatar
The oil temps went up fast likely because when you used the paddle shifter you ran the engine RPMs up higher than if you left the car in Auto mode. Certainly I notice the oil temps going up and up in a matter of seconds when I start running the RPMs up over 4000 and keep them there for even short, but sustained driving. The C7 could seriously use a much more effective engine oil cooler as opposed to that useless heat exchanger. I plan on putting one in as soon as the aftermarket offers it.
Quick Reply: Oil Temperature and Paddle Shifting
