Tires
Tires
I realize that this is a C7 forum, but with a lot of former C6 owners here... Anyone have recommendations for my bosses C6 tires other than OEM run-flats? All seasons for here in central California.
Darn-near any tire but the OEM Runcraps are an improvement.
Does the boss want RFs or non-RFs? Work from there.
Is his C6 a base, GS, Z06, ZR1? Different tires available for different strokes.
Received 2,225 Likes
Carry a small cheap air compressor for added security.
The last flat tire I had was in 1995 and it stopped me cold on the shoulder of I-44 on a Saturday night, about 90 miles from home. Lucky for me it was my sedan that had a spare in the trunk, and the highway had a wide shoulder and it wasn't snowing or raining.
I drive my C6 Z06 on long drives(just got back from a 3400 mile trip through eight states to visit eight national parks, out west in CO, AZ, and UT). You get a flat out there, and you're a long way from home. Thus I have run flats mounted(just in case) on my Corvette.
If I were a waxer and only drove my Z06 locally around town, I guess I would consider non run flats.
Of my four cars, three have spare tires and the fourth has run flats.
Worrying about a "blowout" is like worrying about getting struck by lightening with today's tires. Almost all tire problems are caused by nails, screws, etc. in your tire that cause a slow leak. In most cases as soon as you get a low pressure warning, head for a gas station and fill the tire with air. Don't pull out the nail. That will usually get you home to deal with the problem.
I'm using the exact same tires on my c7 that I had on my c6, I'm not looking for a racing tire of any sort just everyday driving.
My tire of choice is Micheline AS3, they also are the same tire that I run on my c5z
Received 1,738 Likes
St. Jude Donor '15-'16,'18
Check out the new Conti DWS O6 on Tirerack. Better handling than the original. I'm putting a set on my C7.
Did these come out recently? I knew they were coming out with a new revision but there wasn't any obvious info on Tirercrack about the DWS being new. Haven't looked for a couple months though.
Don't underestimate the new crop of runflats, especially Michelins. Far far better than the OEM C6 Goodyears... Unless there is a compelling reason to go with non-runflats I would suggest he go with the added security of a good current technology runflat.
