C7 A/C not up for the summer heat
I see many complaints regarding utilizing AUTO mode for the AC. I can't guarantee this will provide everyone with the "fix" you want, but I (and others) have found that if you go into the Settings Menu and set the Fan Mode for Auto to go to Max, rather than Medium (which I believe is the default), this allows the AC to run full blast until the cabin is cooled, at which time it will reduce fan speed, accordingly.
Since making this simple change, I find AUTO mode works great to run the AC... even during the current "Heat Wave" we're experiencing here in "Portlandia"! --- It's a quick settings "fix" that I at least recommend giving a try. Good Luck!
No problem here in Maryland, even with the high heat and humidity. A/C and seat cooling (ventilation) all work fine. Coolness into lower back is NICE!
Another recommendation to take it in to dealer for a look-see.
I've noticed that the cool seats don't cool very much. Also the AC is not very strong. I think it has to do with the placement of the center vent being so high, and that the 2nd center vent is pointed at the passenger. I can't really direct the air flow on my right arm or lower chest. I often end up lowering the window and let the wind in.
The other thing is that I tinted the windows, 1 shade over the legal limit, but it's not enough IMO. It's not even that hot here, around 76 degrees, but the UV is strong.
Do you have the same issue? I don't suppose there's any easy fit.
On the flip side of the coin, I had the roof off one night and it was getting cold, about 60 outside + wind. I turned on the Auto Climate control to 75, and the car blow ice cold air. So i had to turn it off.
Are you using auto or just the AC? I noticed the auto in this car doesn't work all that well, I just turn the temp **** down until I like the air temp, and set the blower speed at 2. I don't have tinted windows but my car is white, I'm sure that helps.
At slower engine speeds, the A/C compressor is also turning slowly, and not working as effectively. At low road speeds, you're not moving as much air through the A/C radiator, so it's not going to cool as effectively. In those situations, switching to recirc can help a lot, as it will any time you feel it's not cooling well enough.
Also, if you're in auto mode, note that there is a setting to control the maximum fan speed in auto. By default, it's set to medium, which may not be ideal when it's really hot out.
I find my A/C works fine when I'm moving at reasonable speeds. Not so good at idle, but switching to recirc helps a lot then.
No problem here, but I had the heater on today as it only got to 49. The heater works well but unfortunately I can't test when it get down to -40 here as the snow is too deep.
No problem here.
Now someone else post no problem and their location like 2 pages of that doesn't help him.
In order for the "ventilated" seats to "cool," you'll need to direct cool air to the floor area by selecting the appropriate button.
Ventilated seats only have a fan with no actual cooling function. If the air on the floor is hot, then air being vented through seat will be warm as well.
#33
For those having issues, have you tried changing the settings to allow the fan to run at max speed when in Auto mode? If the car is hot to begin with, like if its been sitting in the sun, and the fan can't ramp up to maximum, then I could see it taking quite a while to cool down.
Did this on mine. Works fine now. The "cooled" seats are not air conditioned, it just pulls ambient air so if it's not cool, neither will the seats. If it's over 90 and I have the top off, I've found if you run the A/C on recirculate, fan full, and vents and floor, then the seats get enough of the cool air to stay relatively comfortable.
#34
It's been 100-116 here in Vegas and I'm surprised how good the AC is. Even sitting in stop and go trefoil no issues. Go see you dealer!!
#35
E-Ray, 3LZ, ZER, LIFT
Received 9,656 Likes
The fan in the seat only blows whatever air is in the car.
#37
At spring mountain the 2 days I was there temps where 110 and 113. A/C did a fine job even while at idle and on the track.
#38
Thats why I opten to not get the transparent roof on the C7. Nowhere near as warm inside, and I dont think I'v evef had thhe fan more than 3 clicks.
Also try using bi-level, and make sure sync is on. It does make a differnece if your passenger has boosted the temp on that side.
