Pull Down Latch Retrofit
Ok, there have been quite a few threads about the desire to retrofit the 2016 pull down latch on to the '14 & '15 year coupes. Being the curious guy I am, I contacted Gene @ CultRag and he said that he could now order the 2016 parts.
I hope Gene does not mind me posting this information:
Normally, I would not at all mind attempting a challenging mod like this but I have some personal stuff going on. So I need some help.
I think that we need to find an electrical schematic for the 2016 and find out how this control module is wired into the car, what systems it connects to. Anyone have a source for the 2016 electrical diagrams? The 2014 or 15 diagrams would be useful too as a comparison.
The latch is $175.50. It appears as if there is a control module controlling the operation of the latch and that is $215.26. We would have to find if a connector is available. The problem you're going to run into is the body control module probably tells the module what to do which tells the latch what to do and you may or may not be able to program the BCM to do this. Parts are available. Would take me 4-5 business days to get. Nothing special on the diagram. Just the latch and module bolted to a bracket. I have no further information.
That's a lot of money to spend to avoid putting your hand on the hatch to close it.
Good luck with the retro, OP. Im sure it can be done, just not sure it's worth it.
E-Ray, 3LZ, ZER, LIFT
Received 9,608 Likes
You're fortunate if your hatch latches by using "a swift motion." Some of us have hatches that will not latch no matter how hard you pull down using the GM hand hold unless a door or windows are open (received my C7 in October 2013.) I have been keeping my door open for 19 months, no big deal but just bought a Window Valet so I can open both windows buy hitting my key FOB "door open" button 3 times! Great for the summer as well.
In addition, folks from 2013 were warned at Museum Delivery NOT to push in the center of the hatch to latch as the paint can crack! They were told to use two hands at the peaks near the hatch window outside edges. One poster recently said not just his paint but the hatch cracked from pushing to latch! In fact when I first tried to push to latch I saw my hatch frame bend - so stopped! For some cars it may work but not for all without consequences.
Just validated when I made a PDF of the Window Valet install, my hatch won't latch no matter how hard I pull down but with the windows open it latches with one finger! Happiness is a light Vette!
GM knows the problem is wide spread so went with what I had on my C6, a pull down latch for 2016. Will be interested to see if it can be retrofited
I think you should post a video of you closing yours with the doors closed and windows up. Not that I don't believe you......
I place my hand on the center edge of glass and push down gently, never touch the hatch itself.
I've always but my palm on the edge of the hatch and slammed the hatch down. Slammed sounds harsh but it's not that forceful.
Did it in my 2014 and my 2015 no issues at all. No cracks, no finger prints.
I've been reading on this forum for months while waiting for my ordered 15. I was shocked at how easy the hatch is to close. I pull it down until clasp is resting on the latch and then push down in the 2 creases. Incredibly easy.
Because some fools will make something out of nothing.
I wasn't aware GM decided to add a pull-down hatch mechanism to the '16's. Interesting. So the hatch on the 16's will close like a Cadillac hatch now, eh? I just leave my door cracked open a bit, then close the hatch. No biggie. I would have rather seen GM add a Blind Spot Monitor.
Don't want to rehash some previous responses to that type response with a pic of my weight machine and treadmill but I have been lifting for ~30 years, 7 days/week! Do 3 sets of 10 tricep push downs with 70 pounds and another 3 sets of 10 with a rope grip as part of my arms/chest day routine. On back day do 3 sets of 10 chin-ups, etc. Not bad for a 72 year old! Some folks who's hatch latches fine, seem not to understand some don't!
From when I got my C7 in October 2013 some folks would say I just didn't know how to close the hatch, "watch this video" etc because theirs worked. After trying many things gave up arguing! Just keep my door open. The cars are different.
It is and in the hot summer, nice to open the windows before you get in! They are sold for many cars, mostly for that purpose. Recently designed to fit the C7 Vette. No alterations to the car.
Yep! GM finally admitted there are enough of us where the memory wire activated vent wasn't large enough and they paid for enough paint cracks etc to go back to what did work, a motorized hatch latch. That is what I had on my C6!
Since I got my C7 in October 2013 I have tried many things: 1) checked my vent, it opens as designed just not big enough, 2) readjusted the hatch stops to a point of misalignment in both directions-no help, 3) tried pulling down from GM handhold from high/low, with lots and little force. In fact just validated when I made the PDF of the Window Valet install, unless a door or the windows are open, no matter how much (or little) force I use it will not latch. 4) lossened the latch bolts and closed it several times to try to realign-per a post about what a dealer should check- no help, 5) even if I press, as suggested by GM, with two hands on the window edge I takes a great deal of force and the hatch frame can be seen to flex-so I don't!
It amazes me that with the door open I can stand just behind it and with a slight push down on one side of a fully opened hatch, it latches every time. Proved to me over a year ago the vent is just not big enough for some cars. Happiness is a tight Vette!
I too am following this and other threads on the retrofit of the motorized latch. While I can close mine with enough force, it is sufficient that I worries me about cracking body and paint work. Would rather have the motorized latch that just works.
More 1st world problems.........The 2015 is manual close....2016 adds the auto latch.
Bring the hatch down slowly to a nearly closed position. Now just push down on it near the edge of the window to close.
There is NO need to slam it down!
