LG cooling kits for engine and paddle shift C7's
Premium Supporting Vendor
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
Hi Folks
If you are tired of the car going into reduced power because of overheating the transmission or getting worried about the Engine temps, we have our LG Super Cool packages for both.
We have developed or LG Super Cool Engine Radiator for all C7 Corvettes.
In stock and available.
**In addition, for the Paddle shift cars, we have a track tested Transmission cooling solution for the cars.
Larger Radiator for the rear fender location with a direct bolt in. Plus our own C7 Transmission oil pan that holds a full gallon more fluid without losing any ground clearance.
For the hard core track racer, we also have a kit to add a second cooler in line to add additional cooling for the hard core.
Anthony is posting up our photos on Monday, but you can call LGM and get what you need
thanks
Lou Gigliotti
LG Motorsports
972-429-1963
thanks
Lou Gigliotti
LG Motorsports
972-429-1963
Hi Folks
thanks
Lou Gigliotti
LG Motorsports
972-429-1963
thanks
Lou Gigliotti
LG Motorsports
972-429-1963
Does your new radiator addresses any of the oil cooling issues directly?
Appears to me that the main engine cooling issue is insufficient engine-oil cooling. My engine oil skyrockets to 290 F in a matter of a very few minutes even though the coolant is still around 230 F. That indicates to me that it is the oil in the heat exchager that ends up heating up the radiator coolant under sustained hard runs.
We like to stay around 200 on the race track for best power and protection.
LG
I don't track my C7 but, my temps go to 290/230 in a matter of a few minutes under 2nd/3rd gear, high rpm road driving even at 77 F. If I can get those temps down to say 200-220 coolant and 240-250 oil, I'd be sold.
I agree with you that 230 is too high. The question is what kind of coolant AND engine-oil temps can we expect from your upgrades, say at 90F ambient temps, under either track use or high rpm, low gear canyon runs?
We will keep you posted
Lou Gigliotti
