How to put a C7 on (4) jack stands in 2 minutes
1. Lift from front puck only & place stands
The lifting picture shows the jack placed at the rear lifting point ??
Question.
On my C6 Z I lifted both front and rear wheels from the center rib (middle of door) and then place jack stands on normal jack points (with pucks). The C7 doesn't look like the center rib is as strong as the C6. Has anyone tried this? It sure makes jacking the car easy. Thanks
Question.
Received 1,762 Likes
ttt
Nice write up & car, glad I have a 4 post lift just drive onto it & lift car 8 ft high.
St. Jude Donor '15-'16
On Sale for $140 (regular $230) at Harbor Freight...
http://www.harborfreight.com/2-ton-l...ump-62310.html
It's always at that "sale" price. Great jack. I've had one for 2½ years. Use a 20%-off coupon from a Car & Driver or other car mag ad and you're at $112. Wait around a while and it'll go on sale for around $120, which will bring you down to less than $100 with the coupon.
BRomanelli (11-07-2015)
How to put a C7 on (4) Jack Stands in 2 minutes
Picked it up on sale for $89 during one of their parking lot sales.
This is the same procedure I used on my C5 for 12 years with my harbor freight low profile jack and craftsman stands. The only difference is that I use the correct jack stand locations... OP has them on movable suspension parts...movabity+jack stands=bad :-)
#33
Received 2,680 Likes
2018 C5 of Year Finalist
Where are the correct jack stand placements for the C7?
#34
https://www.corvetteforum.com/forums...fications.html
But I note the owner's manual for my 2015 actually shows the center of both front and rear cross members as acceptable, too.
#35
https://www.corvetteforum.com/forums...fications.html But I note the owner's manual for my 2015 actually shows the center of both front and rear cross members as acceptable, too.
I know where to lift it, just not where to place the jack stands after its lifted.
#36
The jacking instructions are in the manual (p. 10-4). Jack the car at one of the blue lifting points and insert a jack stand at the corresponding red point (i.e., left front blue at left front red). I've done this several times since Jake first posted and it works great.
#37
Thanks. However I thought those jack stand locations were questioned in another thread. On the C5, I used the block of wood underneath the front and rear crossmember method.
The following 2 users liked this post by MSG C5:
McCarthy (03-23-2016),
WetMountainMan (08-23-2019)
#38
This is about a fast/simple/safe/reliable way to get the job done...works like a dream.
Doubters, please follow the owners manual.
#39
#40
What is that round item in the pic, just left of the stand. Referring to the pic of the single rear jack stand.
