Relaced Run-flats with Non-run-flats!
Yesterday, I replaced my Michelin Run-flats with Bridgestone S-04 Pole position tires. I was amazed at the low tire noise level and the comfort experienced! Handling characteristics reflect excellent grip with a slight reduction in initial turn-in, but still very "crisp"! Yesterday, I got to drive in heavy rain and not a hint of hyro-planing in several spots where water was pooling up on the highway. Based on the short time I have driven on them, I am totally satisfied with the performance of the Bridgestones at roughly half the price of the run-flats!
I can't remember the last time I had a flat tire, but I have always carried a "plugging kit" for that rare occasion you have a puncture.
A couple of weeks ago Consumers Report ran an article indicating the public now does not think the run-flats offer much of an advantage over a standard tire. In a lot of cases, you can be stranded for days in some areas where the run-flats are not kept in inventory and you have to wait for them to be shipped to your location.
http://www.consumerreports.org/cro/n...ires/index.htm
I've been considering this, too. I think the lighter tires would aid the suspension response. Trying to plug one on the side of the road might be a significant hassle though and it would be a bummer to damage a wheel.
I hate run-flat tires... its a technology for clueless idiots who cannot use a simple tool, and allows the MFG to delete the spare tire.. saving cost.
Most flats occur for two reasons... a nail, or a catastrophic impact.
At least in my state, a "patched" or "plugged" run flat will not pass inspection. And a "run flat" subjected to a catastrophic impact will come apart in 40 miles of driving.
Basically, a "run flat" guarantees that you have 40 miles to drive to the nearest tire dealer to pay full retail for a replacement.... probably about $350 if you are lucky.
If you are on a trip on Sunday afternoon, and you hit a pothole... well find a Motel 7.5, have a gourmet meal at the nearest Crappleby's and move your schedule back two days.
Received 1,738 Likes
St. Jude Donor '15-'16,'18
Had a set of Continental DWS 06 tires installed today. Noticeable difference in ride quality and noise level. Very pleased with my decision. Sold my OEM Michelins with less than 100 miles to a friend with a C6.
Received 3,290 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
They dismount every tire looking for ganga...
I'm not a tire engineer, but my understanding is that the manufacturer's specification will not support a patch or plug, and the tire must be replaced...
That said, if you slip cousin Louie a hunny, you can probably buy a sticker... different story.
But if somebody can post a manufacturer that will legally support patching or plugging a run-flat tire, then I'm interested.
FL Events Coordinator
They dismount every tire looking for ganga... I'm not a tire engineer, but my understanding is that the manufacturer's specification will not support a patch or plug, and the tire must be replaced... That said, if you slip cousin Louie a hunny, you can probably buy a sticker... different story. But if somebody can post a manufacturer that will legally support patching or plugging a run-flat tire, then I'm interested.
Selected Tire Manufacturer's Policies for Run-Flat Tire Repair
The following list summarizes tire manufacturers' repair policies, however it should be noted that every tire manufacturer that consents to repair, does so only after the punctured tire has passed a thorough exterior and interior examination.
Manufacturer/Brand Repair Policy Additional Provisions
BFGoodrich Permitted 1 repair maximum
Bridgestone Permitted Only if 15 psi maintained
Continental Does not recommend Mfg. Road Hazard Program*
Dunlop Permitted
Firestone Permitted Only if 15 psi maintained
Goodyear Permitted
Kumho Permitted
Michelin Permitted 1 repair maximum
Pirelli Not endorsed Mfg. Road Hazard Program**
Yokohama Not to be repaired Mfg. Road Hazard Program***
*Replaced free of charge first year or first 2/32" of wear (whichever comes first). Continental advises that a repair to one of its tires invalidates all other manufacturer's warranties.
**Replaced free of charge first year or first 2/32" of wear (whichever comes first), then prorated until worn to 2/32" of remaining tread depth
***5-year prorated replacement until worn to 2/32" of remaining tread depth if punctured in RMA defined repairable area
Use of run-flat tires deemed non-repairable may result in vehicle or property damage, as well as can cause personal injury or death.
Tire Rack will not repair any run-flat tires that have been driven in a severely underinflated or zero pressure condition because the service conditions they experienced and integrity of their internal structure cannot be confirmed.
Michelin (and others) does support a one time patch on their run flat tires as long as the puncture is not on the outer portion of the tire.
Dunlop Permitted
Goodyear Permitted
Kumho Permitted
Dunlop Permitted
Goodyear Permitted
Kumho Permitted
My take-away... subtracting the legalese, of course, is that, if you are willing to spend $350 verifying that the repair meets specifications, you can save spending $350 on a new tire...
Or words to that intent...
RF or non RF, the chances of a tire fitting the Corvette being in stock are slim, at best, so you are likely to be stuck, anyway. If you want to drive a long way from home, and want a car where a tire is likely to be a normal stock item, then drive a Prius.
The thing the anti-runflat crowd seems to forget is that the Corvette has no jack, no lug wrench, and with a flat tire almost no ground clearance. Good luck finding the puncture and plugging it with an inch of ground clearance around the flat tire and no way to remove the wheel. Then again, you can drive on the shoulder at 2 or 3 mph until the tire is totally destroyed and comes off the rim, and hope you get to a tire store. And then wait for them to order one that fits your Corvette, because they probably don't have one in stock, run-flat or otherwise.
But what state do you live it? I'll make a note never to move there. That intrusive an inspection process is absurd. Some inspection monkey damages a $500 rim and I see a lawsuit in the works.
That is a seriously awesome piece of research... kudos to you... My take-away... subtracting the legalese, of course, is that, if you are willing to spend $350 verifying that the repair meets specifications, you can save spending $350 on a new tire... Or words to that intent...
First, most manufacturers say it's fine to patch/plug a tire from the inside. Some specify one repair, some allow more. Tire Rack had an article on tire manufacturers repair policies, but I can't find it at the moment. (Edit, I see it's been posted above.)
Good point.
"Run flat" is a legal concept that has nothing to do with actual tire construction or performance.
Let the air out of two identical tires; one RF and one not. Drive each for 50 miles at 50 mph. Let us know how it works out, and be sure to post pics of the damage to the car and wheel with the non-RF tire.
Received 19,305 Likes
'20-'21-'22-'23-'24
Well, this CLUELESS IDIOT will laugh as he drives by you as you lay on the ground trying to find out why you have a flat tire....This has been discuss ad nausem on every Corvette Forum since the introduction of the run flat tire. If it makes you feel good to drive on run flats....GOOD....But me thinks the clueless idiot is YOU.
Even posting a picture like this:
which shows that you can drive long distances, with no rim damage, on RFs after something catastrophic, is unlikely to change the opinion of someone who thinks they are bullet-proof.
"Run Flat" lets manufacturers sell cars without spare tires, jacks, tools, and the ability of the driver to actually change a flat tire... as a poster pointed out
It simply means that the sidewall construction will support the weight of the car for 50 miles at 50 mph.
Most modern, low profile performance tires can do that too, they simply have not met a governmentally approved standard that the lawyers can defend in court.
I have driven racing tires on track with almost no air in them, and the sidewall stiffness kept them on the rim and functioning.
And yes, I drove a "run flat" for 50 miles... pothole damage, and it was totally destroyed and had to be replaced... $350, and a flat-bed charge, btw... no spare... so thanks.
The OP was stating that modern high performance after-market street tires perform well compared with "run flats" is accurate.
My point is simply that "run flat" is a legal term that protects manufacturers from litigation and has very little real-world value on a high performance sports car.
also curious if anyone else can comment on the S-04's?
I wonder what a C7 would look like with a continental kit on the back.
(just kidding folks).
Basic flawed logic. If one has a non-reparable flat on a RF, it need not be replaced with a RF.
Jimmy
