Is A Fix In Place For The HVAC System Blowing Hot Air When The A/C is Off?
I think you misunderstand the issue, it has nothing to do with the car sitting in the hot sun. In fact, it's just the opposite. As an example, my C7 is parked in the garage and cool. I drive it in 60-70* OAT. No AC and nice cool air flowing through the vents. 20-30 minutes later, with the engine running hot for a bit, the non-AC cool air has now turned hot.
Can turn the temp control all the way down to "Lo", doesn't help. Turn on the AC and instantly cool. I've owned dozens of cars in my life (none as expensive as a C7) and this is the only car that's ever behaved this way.
There is an HVAC reflash that applies to my car (an early 2015 model) that I thought had fixed this problem -- it must have just been extra cool outdoors that day as the problem still exists as it has since day 1.
For now, items 1) thru 3), above, are our only solutions, as near as I can determine.
Ernie
It's not very far from there to the vent, I'm surprised it heats up as much as it does.
The couple times I've ridden with the top off I had the A/C on because it was warm air coming out with just the vents. Seems kinda counter productive.
I don't think some of you guys understand the problem.
In my Jeep Wrangler .. if I have AC on the blower is on ... If I turn AC off the blower goes off.
In my Ford Focus ... if I have AC on the blower is on ... If I turn AC off the blower goes off.
In my C7 ... If I have AC on the blower is on. If I turn AC off the blower STAYS on ...
That is the issue.
That is the issue.
Hitting the recirc button in addition ensures no air forced through the vents by the motion of the car.
Mine still has hot air coming in even with the fan off. With the blender in Lo no hot air should ever come in no matter what the fan is doing. I long for the days you could order a Corvette with a manual HVAC system.
Received 2,379 Likes
Sure there is a fix.....winter. If you are hot, turn your AC on. Seems like common sense to me! If you turn your AC off around here you will die in a matter of minutes. No different from being in space without a helmet. Yes, your head WILL pop.
See the pic in the other thread where the outside ambient air temp is 60 degrees but the temperature of the air from the middle vent (with no heater on) is 106 degrees. Are you seriously saying that at 60 ambient you should expect to turn on the AC? I don't.
The fix is to turn off the vent/blower system completely. No air circulates through that system at that point. This is annoying to me because on my other cars the vent system brings in fresh cool air but on my C7 it does not.
But is this a reason to sue GM, return the car or drive it into a lake? No.
You're missing the point, but I can't tell if you care or are just trolling.
If it's 106 with a 60 degree ambient then yes, that's a problem.
Mine doesn't do it.
That's why you put it in recirc.
Yes, I agree the system should allow cool outside air in when the A/C is off without heating it up. But it doesn't, so the best you can do is prevent the hot air from flowing into the interior.
The Stingray isn't unique in this respect. My last car was the same. I think manufacturers just assume people are going to run the A/C when it's warm out, and don't worry about this any more.
I think everyones C7 Stingray or Z06 does this as I have yet to find one that does not.
It is by design as the hot engine bay heats the firewall which in turn heats the vent ducts.
I also do like meyerweb in my area where ambient temps are moderate. Turn off fan, leave in recirc. and open the window(s) usually passenger window enough to bring in the outside air.
First car I have ever had to do this! But also first car with 650HP
#33
#34
#35
I can drive with the fan on at any speed and it blows near or maybe a little below ambient temp, which is what I would expect without the AC button pressed/compressor on. In fact, I do this regularly to eliminate the loud condensation burn off upon parking in the garage. I turn off the compressor 5 minutes before I get home with no strange effects/temps and my ambient is 95-105 in August. I usually go from AC on/temp set to 60 and switch the compressor off and sometimes crank the temp to 70 or even 80 to blow condensation out of the vents, too.
#37
I wasn't trolling if it truly doesn't happen on my car, I am not familiar with what you're experiencing.
I thought my car didn't have this problem, until I switched the auto-defrost setting.
#38
Received 3,290 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
Why not just leave the climate control system in auto mode?
#39
Check the settings in the infotainment system and see if you have "auto-defrost" selected. If you do, the car is sometimes running the A/C even when you don't think it is, with no indication on the dash at all. If that setting is set on, turn it off and see what happens.
Auto mode doesn't work too good on mine. Almost like it's dumb. Plus Auto always turns on recirc, which I don't like. I prefer fresh air unless I am behind Uncle Buck.
#40
Gents, one KEY HVAC function has changed since the early 2014 builds (and subsequently became an update for those cars): The LO setting initially ALWAYS ran the AC - even with no light/indicator showing.
My first 2014 C7 (built in mid-September 2013) was this way. So I left it set to 61...to avoid this.
The current HVAC programming (changed in early 2014 by all accounts) now DOES NOT turn on the AC in the LO setting - hence the hot air blowing. My 2nd 2104 C7 built in March 2014 and my 2015 built in December 2014 had the update and did not engage the AC when on LO.
And my 2015 blows pretty warm when on LO as others have noted - even when not terribly warm outside. So I turn the fan all the way off. I don't consider this a defect as there's a lot of hot stuff for the outside air to pass over before it comes out the vents. If I wanted it cooler, I'd turn on the AC. So to the OP's post, I don't think there's a problem to fix when the HVAC is in a "passive" state.
And as meyerweb indicated, another complicating issue is the Auto Defog option. The default is ON, which will also engage the AC when conditions warrant (humidity vs. temperature). I also discovered this early in my C7 ownership and turned it OFF.
I never use the Auto setting, so can't comment on its effectiveness.
