Loud flapping vibration sound in front of car at low RPM
Old 09-16-2015, 08:29 PM
cattman
cattman's Avatar
Default Loud flapping vibration sound in front of car at low RPM
I am getting a flapping/ vibration sound in my 2014 Z51 A6 that sounds like it's coming from the front of the car. Happens consistently when cruising (foot even on pedal, neither accelerating nor slowing) at low RPM's. Sounds like gravel being shaken in a plastic water bottle. It's been getting worse and worse. I have 14k miles.
Anyone have any idea of what this could be, or have the same issue and get it diagnosed and resolved?
CATTMAN
Old 09-16-2015, 08:53 PM
TNSQUIRE
TNSQUIRE's Avatar
Originally Posted by cattman
I am getting a flapping/ vibration sound in my 2014 Z51 A6 that sounds like it's coming from the front of the car. Happens consistently when cruising (foot even on pedal, neither accelerating nor slowing) at low RPM's. Sounds like gravel being shaken in a plastic water bottle. It's been getting worse and worse. I have 14k miles. Anyone have any idea of what this could be, or have the same issue and get it diagnosed and resolved? CATTMAN
Have your dealer check the hydraulic belt tensioner. Known issue on 2014 models
Old 09-16-2015, 08:57 PM
bjhayes
bjhayes's Avatar
Torque tube issue?
Old 09-16-2015, 10:35 PM
proeagles
proeagles's Avatar
Received 2,132 Likes on 892 Posts
CATTMAN
Have you looked under the car to see if you haven't accidentally torn the rubber air dam and perhaps it is flapping?
Old 12-30-2015, 01:21 PM
vinnie12345
vinnie12345's Avatar
CATTMAN
Any new news?
Old 12-30-2015, 06:20 PM
hisvett
hisvett's Avatar
St. Jude Donor '14-'15
YUP!! Mine ('15 Z51 @ about 15K miles) did it in 4cyl mode only with slight acceleration, 30 to 50 MPH.....sounds like plastic vibrating. Made an appointment at the dealer.....about an hour later had the new lower idler installed and was back on the road. You can check it out with a flashlight....very low on the front of the engine, more to the passenger side; check with finger for oil on tensioner. No issues since
Old 12-30-2015, 07:24 PM
lancekl
lancekl's Avatar
CATTMAN
You don't have a missing cat do you?
To Loud flapping vibration sound in front of car at low RPM
Quick Reply: Loud flapping vibration sound in front of car at low RPM
