Forum Dealers Question - AFM Valves
AFM Valves - Forum Dealer Help?
Hello Forum Dealers,
I know you are all very busy, so I am posting this here just as a "whoever may have time to answer" quick question for you:
Does the 2016 Z06 come with AFM valves, in addition to the NPP valves? Or, on the Z06, are the AFM valves run as a part of the NPP valve configuration?
I've read every thread I could on this subject, but found no definitive answer, and I figured you'd be in the best position to know.
Here's why I ask: I am interested in installing a cat back system, and not certain (because I can't find a definitive answer in any thread) that I will need to solve for running (or not running) the AFM valves.
I know many of you are selling cars around the country, so perhaps you'd know the answer by having seeing the cars during PDI.
From what I have read, I think some base and Z51 C7 owners would also be interested in knowing this answer.
Any rhyme or reason as to why or why not the AFM valves are present?
Very much appreciate your feedback.
Platinum Supporting Dealership
Also GM does not recommend modifying the exhaust system in any way and your warranty will be voided.
Dave
I am glad (and would only ever get) that I purchased an M7 with my vehicle. But, this gives me reason to pause on any cat back exhaust install, even if I like the sound and black anodized tips much better.
I wonder if all others who have made such cat back installs are aware of voiding their warranty, having done so.
I'm glad I checked. I believed the only thing affected by a cat back system install would be that part of the warranty covering the replaced factory installed cat back system.
So installing a cat back exhaust system voids the ENTIRE warranty? Yikes.
Again, thank you for your time, Dave.
Borla? Corsa? Magnaflow? et al?
Exhaust resellers, just curious if you are advising Corvette owners who have vehicles under warranty that by installing (at least some of) your products it will void their GM warranty.
This could prove (potentially) useful as a consumer of your products, especially for a consumer such as myself who is asking questions to be an informed consumer.
Hopefully you've had no warranty issues with the changes you've made.
The Consigliere
Received 5,441 Likes
OP - I have an M7 Z06. No AFM valves. So you don't have to worry about those.
Mine also doesn't have the NPP valves any more as the exhaust got changed out.
I guess I can install the cat-back system, then leave the car hermetically sealed in my garage (except for once weekly waxing - needed or not - in which case I will roll it out of my garage to do so, do the waxing, then return it to its hermetically sealed garage container) until the warranty runs out, at which point I will start the engine, and not worry about the warranty any longer since the warranty will have expired.
Of course, not having started it for another three years may cause its own problems.
Damn, I'm really screwed now!
I knew I should have bought that 1971 Ford Pinto off ebay!
The Consigliere
If you retain the stock exhaust manifolds, stock cats (and leave the cats in the stock location), you're not going to have an issue with exhaust messing up your warranty.
I've never heard of an axle-back or cat-back exhaust set up resulting in a warranty problem.
Put headers on, remove the cats, or even move cat location, and yeah, they can jack with you on that if they choose to do so. So just go into that scenario with your eyes open if you're contemplating making those types of changes.
What did you get, by the way?
I'm looking at the Corsa X-Pipe and Extreme axle back with quad black outlets configuration.
Hopefully, this will sound like an American V8 once installed.
The Consigliere
Mine got the Callaway exhaust set up (which I think they sell separate from their performance package if you're interested in that one).
Just this past weekend, I met a chap with a Z who has the Corsa Extreme with those quad black tips. Tips looked great. And it definitely did not sound like stock exhaust. I didn't ride in the car, so I don't know how well it manages drone, but Corsa has a great reputation managing drone well, and they make high quality stuff. It definitely ripped, though - noticeable change from stock.
Drone inside the car at highway speeds was really bad on C5s and C6s with deep musclecar sounding exhaust or open NPP. Corsa's were ok because the their higher pitched sound avoided those deep tones. But is drone even an issue with the C7? Better sound insulation and other changes seem to have greatly reduced the problem.
