Acceleration
Acceleration
Ok - please be kind all, need some advise. The one thing that has always annoyed me with RWD is that, at times, it feels like there is the delay between press pedal and go. I got the vette because it has a lot of power and its light for a sports car.
I feel like the car either is very lax or I have to really push it then its like I am racing.
Some rare times I can hit the pedal just right and its like the car moves with effortless grace (15-40mph range) like it has power and it needs next to nothing to move like a cheetah.
My question is this, is there something I am doing to cause this? Is it heat soak or to much AC blowing? Have I become use to the power and no it feels less now? I know this is all very subjective. I just feel like there are times when I accelerate its like pure class and it takes nothing for the vette to move through traffic and some times it feel like I have to kick it harder then I think it needs.
Any suggestions? At times it feels, to me, like maybe the gas pedal is to stiff. I don 't know.
I'm sure it's just the designed in "slow ramp rate" of the drive by wire system.
Have you tried it in Sport or Track to see if it feels the same?
I 99% of the time drive in Sport. I'm going to try track tonight to compare.
It's just weird because at times its effortless grace and some times it feels like beating a tired horse.
DeStreGa5 (10-08-2015)
A8. It's weird, don't know what to call it. I don't feel like its hesitating, so much as at times its take less to get it moving then others. It comes off as effortless grace when its fine and having to floor it some when it doesn't. I never feel like its holding back, more like its not sure how much pedal it wants? I's like at times I have a stiff pedal.
Probably emission system related. You could go to the dealer and check for codes. With all the sensors, probably something you will be living with. Driving rental cars like I do, some just don't perform.
Initially, I felt the same way about my late 2014 A6 with respect to off the line response and here I'm speaking only of street driving in normal traffic, not trying to show off at a stop light, something I don't do anyway.
For whatever reason, the sluggishness I felt went away pretty quickly and I am completely satisfied with the throttle response at any rpm. Don
It's really Physics. When you give you car gas with a rear drive car there is a time delay from the time the engine torques and it moves thru the drive shaft out the axles to the rear wheels. There's less distance to go in a FWD car but there's always a delay. If you don't believe me watch some drag racers especially. You'll see the front end rise and the back end seat down....it's simple torque motion. The funny car & pro stocker's set their suspensions to minimize this. However it's still there. Most people don't notice it but that's the bottom line.
I think that's true. I recall seeing a thread about reprogramming the throttle response curve. I think the standard ramp rate was intentional for easier driveability.
E-Ray, 3LZ, ZER, LIFT
Received 9,619 Likes
Simple solution, which he defines works, push the peddle further. He can also get a tune or can buy a device to put in the electrical connector to cause the throttle to open more quickly.
Just my thoughts.
St. Jude Donor '15-'16
If the latter I would say the delay is in the downshifting.
I'd say what the OP is feeling is lag time between pressing the pedal and the throttle responding under computer control. My C4 has a cable operated throttle and feels far more responsive than my C7. Even sitting still and revving the engine is different. Call it lag time, ramp time, whatever, the throttle by wire isn't the same as cable or linkage throttles. Likely its ramp timing to make the car as tame as a family car when driven with a light foot.
Carvin (10-09-2015)
From my personal experience with my Vette I thought some of the same things as OP.
For me its is:
Sport or Track mode.
TC off (hold down TC button until both TC off lights come on dash).
Tons of wheel spin and it feels much more like an untamed animal I don't need no stinking nannies!!!!!
For me its is:
Based on comments here I drop drove into work in sport, like normal, but I 1) when in auto used the paddles to drop gear just before I moved and 2) tried driving several miles in manual mode. Either seemed to have a huge impact in the 20-40.
I think I have a rhythm to it now, but I think I might need a tune to make things perfect.
Does anyone else feel like the gas pedal is pretty stiff? I don't know why I feel this way, just feels stiff to me.
Thanks for all the help!!!
Bruce
