Front cameras are awesome!
Old 10-10-2015, 12:50 PM
ZEEEE06
ZEEEE06's Avatar
Location: PERCUSSIVE MAINTENANCE: The art of whacking the crap out of an electronic device to get it to work.
Default Front cameras are awesome!
My 2016 Z51 2LT has the front mounted cameras and they are fantastic. I am totally confident when parking because I know exactly how far I am from curbs. I pull up using the colored lines and when the red line is on the front of the curb, I know I am 9 inches away.
Casey VP26 (10-11-2015)
Old 10-10-2015, 01:01 PM
rmorin1249
rmorin1249's Avatar
Received 1,738 Likes on 1,174 Posts
St. Jude Donor '15-'16,'18
very useful.
Old 10-10-2015, 01:44 PM
Black&White
Black&White's Avatar
This should have been on the car since day 1
Old 10-10-2015, 01:56 PM
kp
kp's Avatar
While I never whacked the nose on my '14, usually backed into spots if possible, the front camera is pretty useful and a welcome addition. I did come a little too close a couple times..
A couple more rear cameras so you could see the corners would be nice, as well as blind spot/rear crosspath detection but hey at least we got a front camera
Old 10-10-2015, 02:25 PM
eboggs_jkvl
Moderator/Tech Contributor
eboggs_jkvl's Avatar
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,810 Likes on 2,058 Posts
2015 C7 of the Year Finalist
Too bad I can't slap that on my 2014.
Elmer
Old 10-10-2015, 02:54 PM
kp
kp's Avatar
Elmer
Sure you can, trade into a '16 with the same option as yours. Might be a little expensive but you get new tires and wiper blades too
douginkc (12-08-2015)
Old 10-10-2015, 11:44 PM
Support Corvetteforum!
Received 19,188 Likes on 13,911 Posts
'20-'21-'22-'23-'24
Would be great if those cameras were put on other cars as well.
Old 10-11-2015, 08:32 AM
427bob
427bob's Avatar
I already figure I have saved the front spoiler a couple of times by using the front cameras.
Old 10-11-2015, 08:47 AM
cor66vette
cor66vette's Avatar
Received 1,308 Likes on 690 Posts
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
Excuse this question, but do the front cameras record?
Old 10-11-2015, 08:51 AM
fumbling
fumbling's Avatar
Do the front cameras come on automatically when you slow down to stop or do you have to remember to press a button to get the front camera display?
Old 10-11-2015, 09:12 AM
dvilin
dvilin's Avatar
Received 7,918 Likes on 4,804 Posts
Old 10-11-2015, 09:17 AM
b4i4getit
b4i4getit's Avatar
If you are really lucky you may get orange peel where you did not have it before.
Old 10-11-2015, 09:27 AM
direct007
direct007's Avatar
Received 2,005 Likes on 1,024 Posts
If you shift to reverse then back to drive, the front cameras will automatically come on. Otherwise, you need to hit a button on the infotainment screen at speeds under 5mph.
Old 10-11-2015, 09:28 AM
Classic-Chevy-Guy
Classic-Chevy-Guy's Avatar
The front cameras come on in one of two ways:
1) You hit Home on the Infotainment Screen and then hit the Camera Icon.
2) You slow down, put the car in reverse, and then put the car in forward. The cameras then come on automagically!!!
Works great. The three lines for guidance are 36, 18, and 9 inches from the front of the car, so you choose how close you want to be to any objects.
Old 10-11-2015, 09:31 AM
jcthorne
jcthorne's Avatar
Sure hope one of our vendors comes up with a retrofit kit to add this system to prior year cars. I would not hesitate to order.
Old 10-11-2015, 10:15 AM
R23HTC
R23HTC's Avatar
That would be interesting, but I thought it was said it wouldn't work with the current screen? You'd have to update to a 2016 set up all around?
Old 10-11-2015, 10:24 AM
ZEEEE06
ZEEEE06's Avatar
They don't record.
To Front cameras are awesome!
Old 10-11-2015, 12:21 PM
fumbling
fumbling's Avatar
Seems to me the most common scenario to use the front cameras would be pulling in front first to a parking spot without using reverse. Putting into reverse would usually be for backing into a parking spot with the backup camera. Other than parallel parking is it often that a car gets put in reverse then need to use the forward camera?
Old 10-11-2015, 01:10 PM
kp
kp's Avatar
Right, parallel parking is why they do the reverse first/forward thing.
There is a camera icon on the main radio screen (not just the home screen) that you just push on the dash, as long as its not in park and going less than 5mph it will turn on the front camera. They could put an option to turn it on going under a certain mph by itself when not in park but then it would come on every time you came to a stoplight.
It is absolutely no bother at all to reach up and push the camera icon on the radio to turn it on, a billion times better than not having it and plowing the nose into a parking curb thats for sure.
Old 10-11-2015, 01:22 PM
tunaman
tunaman's Avatar
Check out the NavTool threads... Sounds like they have a solution.
Quick Reply: Front cameras are awesome!
