C7 Corvette Custom Fit Dash Covers at PFYC
Platinum Supporting Vendor
2014 2015 2016 C7 Corvette Custom Fit Dash Covers
New lower pricing! Protect your dash or cover a faded dash with these perfectly fitting dash covers, made just for your car. These are not generic. Many colors available.
Our Custom Fit Dash Covers protect and beautify the dashboard of your vehicle. Your dash receives more exposure to the elements of weather (sun, UV, heat, cold, and moisture) than any other part of the interior. An unsightly dashboard is not only bothersome to stare at, but can also be a big expense to replace. This makes a dashboard cover one of the best investments you can make to protect your dash. Additionally, the dash cover protects you from glare while driving. We offer licensed logos and up to 15 letters of embroidery to customize your dash cover to your needs.
Zig Zag Stitching
The manufacturing process uses the zig zag stitch, which acts as a hinge, allowing the material to follow the contours of your dash. Others use a blind stitch, causing the material to curl into the seam, lifting off the dash and collecting dirt and dust. The zig zag stitch makes for the most custom fit possible. The finished dash cover appears more like a 3D product that fits your dashboard like a glove, rather than a bunch of panels sewn together.
Materials Available
Suede: This material is coated with a patented finish to give it a fine sheen and a smooth, luxurious finish. The coating allows easy cleaning and an everlasting finish. These are the finest dashboard covers available anywhere at any price.
PolyCarpet: A super dense polyester needle punch non-woven carpeting of 14 oz. per yard with 4 oz. of latex backing using solution-dyed long life automotive dyes. This results in an extremely robust construction. Polycarpet is treated with fire retardant materials to comply with federal motor vehicle safety standards and are available in a large array of colors.
Velour: A luxurious polyester material with a smooth velour finish. It is laminated with 3/16 inch high density foam to retain shape. Velour covers are available in 12 colors.
Fashion Prints: For an extra touch of personality, specialize your cover with our plush designer velour. These are treated with a UV and fire retardant agent for uncompromising safety. Available in 8 fun styles.
Zig Zag Stitching
Materials Available
__________________
PFYC.COM - Proudly Serving You For Over 20 Years! Call Us Toll Free: 866.695.PFYC (7392)
www.pfyc.com info@pfyc.com .."we're here to help"
joeybsyc (03-18-2016)
FL Events Coordinator
There is a product call AEROSPACE 303 PROTECTANT. If you aren't using it for your dash, seats, seals, hoses, tires; you are really missing the boat. I have used it on all my cars and BOATS since I first discovered it in 1985. It is NON greasy and REALLY protects what you put it on from the UV that comes from the sun.
These also go great with simulated sheepskin seat covers.
I used to use this stuff on the vinyl top of a convertible I once owned. It's good stuff and lasts a long time providing UV protection.
