Stingray J55/J56 Performance Brake Upgrade Kits
Old 10-30-2015, 02:34 PM
0subchev
Former Vendor
subchev's Avatar
Default Stingray J55/J56 Performance Brake Upgrade Kits
Stingray J55/J56 Performance Brake Upgrade Kits are now available from GM!!!
C7 Stingray Brake Kits
Chevrolet Performance announces the launch of the C7 Corvette Stingray Front and Rear Brake Kits to the Chevrolet Performance Parts Program. Upgrade base C7 Stingray to Z51 specs with the J55 kit
Developed by Chevrolet Performance engineers, this performance Front and Rear Brake kit has been designed with C7 Corvette Stingray customers in mind.
For the J56 brakes these are for Z51 vehicles only. Part warranty only.
"Upgrade your C7 Stingray Z51 to Z06 specs with this kit featuring two-piece iron slotted rotors, 370 x 34 mm front and 365 x 26 mm rear, with aluminum mono-block six-piston and four-piston fixed calipers, respectively. The front calipers feature vented pistons for improved brake pad and brake fluid cooling. These calipers offer differentiated piston diameters of 30, 34, and 38 mm (leading to trailing) to provide more even pressure for improved pad wear. Note: These brakes will not fit under Z51 wheels. A minimum of 4mm clearance is required between the outboard face of the caliper and the inner wheel spoke."
For the J55 brakes, it is for base (non-Z51) Corvette only. Part warranty only. It is recommended that buyers also purchase the Z06 grille and front brake cooling ducts.
"Upgrade your base C7 Stingray to Z51 specs with this kit featuring slotted rotors measuring 345 mm front and 338 mm rear. (Base Stingray is 321 mm front.) When installed with the Z51 brake cooling kit, this system will match the braking performance of the Z51 system."
Z51 - J55 18" Brake Kit (Front):
-Z51 J55 Brake Upgrade Kit, with Front Calipers only. slotted Rotors and HP pads.
-18" 4-piston Base Car only - Highly recommended to purchase brake ducts and accessory Z06 grille
Z06 - J56 (Iron) Brake Upgrade Kit (Front Only):
-6 piston front rotors/pads/calipers Z51 only
Z06 - J56 (Iron) Rear Brake Upgrade Kit (Rear Only):
-4 piston rear rotors/pads/calipers Z51 only
If you have any questions, you know what to do
Old 10-30-2015, 09:21 PM
4GS7
4GS7's Avatar
How big of a spacer do you need to run the Z51 wheels with the J56 kit?
Old 11-02-2015, 06:34 PM
0subchev
Former Vendor
subchev's Avatar
"Note: These brakes will not fit under Z51 wheels. A minimum of 4mm clearance is required between the outboard face of the caliper and the inner wheel spoke."
This is all the information I have, but I'll see if I can find out what sort of spacer would make this kit work with the Z51 wheels for you.
Old 12-04-2015, 04:24 PM
0subchev
Former Vendor
subchev's Avatar
Old 12-21-2015, 09:41 PM
4GS7
4GS7's Avatar
Are there different part numbers for different caliper colors?
Old 12-22-2015, 04:45 PM
0subchev
Former Vendor
subchev's Avatar
So far they are only offered in red
Old 01-31-2016, 10:40 AM
hqbrian04
hqbrian04's Avatar
Default non z51 to z06
I have an aftermarket wheels that clears brembo 380mm brakes. Does z06 kit bolt on to non z51 hub n knuckle?
Interested just the fronts. Im keeping rear brake baseline for clearing my drag wheels.
what does kit come with?
Old 02-01-2016, 04:15 PM
0subchev
Former Vendor
subchev's Avatar
This brake kit is built for Stingray with Z51, so I don't believe it will bolt up to non-Z51 cars,
The kit contains what is pictured here
Old 05-26-2016, 02:16 PM
0subchev
Former Vendor
subchev's Avatar
Thanks for all the orders!!
Click Here for Details about our Memorial Day Sale!!
Trunk Monkey Parts | Your Source for Corvette Parts & Accessories
Old 03-29-2021, 03:14 PM
vetguy12534
vetguy12534's Avatar
I have a c7 2019 and have the basic brakes, JL9 so do you know if I can upgrade to the zo6 brakes non ceramic???
Old 03-29-2021, 03:55 PM
JMII
JMII's Avatar
Received 2,025 Likes on 1,349 Posts
You can upgrade if your wheels clear the larger brakes. The hub is the same on all C7s, the calipers just have larger mounting tabs to accommodate the larger rotors. A good write up on the upgrade is here: https://motoiq.com/project-c7-corvet...e-upgrade-kit/
Old 03-31-2021, 04:10 PM
jersphoto
jersphoto's Avatar
The links no longer work. Please correct the links
MyDarkAngel (08-07-2021)
To Stingray J55/J56 Performance Brake Upgrade Kits
Quick Reply: Stingray J55/J56 Performance Brake Upgrade Kits
