Wheel lug nut torque spec?
Old 11-04-2015, 12:55 AM
Maxie2U
Maxie2U's Avatar
Received 4,126 Likes on 2,232 Posts
Default Wheel lug nut torque spec?
What is the correct wheel lug nut torque (lb•ft)? I believe I read on this forum its 100 ft lb but the 2016 owner's manual says 65~79 ft lb.
model year = 2016
Maxie2U is offline
B2Vette (10-19-2018)
Old 11-04-2015, 01:00 AM
gpotski
gpotski's Avatar
Good thing a "normal load" is three (3) people.
gpotski is offline
Old 11-04-2015, 01:03 AM
Rooster OG
Rooster OG's Avatar
Received 1,694 Likes on 1,240 Posts
St. Jude Donor '15
I'm not sure what manual that is but page 312 of the Corvette manual has it at 100.
Rooster OG is offline
Old 11-04-2015, 01:07 AM
Maxie2U
Maxie2U's Avatar
It's from my 2016 Corvette owner's manual, page 486 (8-5).
Maxie2U is offline
Old 11-04-2015, 01:11 AM
JerryU
E-Ray, 3LZ, ZER, LIFT
Support Corvetteforum!
JerryU's Avatar
Received 9,600 Likes on 6,614 Posts
[/IMG]
model year = 2016
Don't know where you got that info from but this is a pic made from page 312 in the 2016 Owner's Manual. It's the same 100 ft-lbs for the 2014 and was for my '08 C6 as well!
PS: My copy of the 2016 Owner's Manual only goes to page 349!
From 2016 Owner's Manual. My 2014 is the same as was my C6.
JerryU is online now
Rooster OG
Rooster OG's Avatar
St. Jude Donor '15
Hmm I got ripped off. My manuals only 350 pages. I guess they left out the third passenger, compact spare and tire mobility kit info from mine.
Old 11-04-2015, 01:17 AM
Maxie2U
Maxie2U's Avatar
Must be past my bedtime! Thought I opened my iBook copy of the 2016 C7 manual, but I actually opened my 2015 Optima manual
Egg on my face...
Maxie2U is offline
Old 11-04-2015, 01:19 AM
Sneakytoot
Sneakytoot's Avatar
Write up from your manual is not even your wheel sizes.
Base Front P245/40/R18 Rear P285/35/R19
Z51 Front 245/35/R19 Rear P285/30/R20
Z06 Front P285/30/ZR19 Rear P235/25/ZR20
Chart does not belong to a Corvette..........
Sneakytoot is offline
Old 11-04-2015, 01:58 AM
///ADMAN
///ADMAN's Avatar
...in a bukkake video
///ADMAN is offline
Avanti (05-09-2018)
Old 11-04-2015, 02:02 AM
Received 19,188 Likes on 13,911 Posts
'20-'21-'22-'23-'24
100 lb ft it is.
Vetteman Jack is offline
Old 11-04-2015, 06:20 AM
SRQStingray
SRQStingray's Avatar
OP, bet you wish you could take that post back
SRQStingray is offline
Old 11-04-2015, 06:27 AM
C7Joy
C7Joy's Avatar
I watched my dealers tech torque mine to 100 ft-lbs, as the book says.
C7Joy is offline
Old 11-04-2015, 07:12 AM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
model year = 2016
Difficult to believe how misinformed some people are. The page you copied and pasted is not even for a Corvette yet you are posting it as fact in a Corvette forum dealing with the 7th generation Corvette.
JoesC5 is offline
Old 11-04-2015, 07:38 AM
green2000
green2000's Avatar
At least the OP attempted to read the owner's manual which is more than many people do.
green2000 is offline
The following 3 users liked this post by green2000:
Glen e (11-04-2015), phantasms (08-25-2017), racedrvr (05-11-2016)
Old 11-04-2015, 10:00 AM
TEXHAWK0
TEXHAWK0's Avatar
That manual cannot be for a Stingray....
Note it has pressures for a spare tire, and shows normal pressure to be 34 psi instead of 30.
TEXHAWK0 is offline
Old 11-04-2015, 10:50 AM
SteveSoCal
SteveSoCal's Avatar
Throw away those nitpicky owner's manuals.
Tighten 'til it strips. Back off half a turn.
SteveSoCal is offline
DickieDoo (11-04-2015)
Old 11-04-2015, 03:07 PM
wgood
wgood's Avatar
model year = 2016
100 ft lb has been the standard for years no matter what car you owned !!! Wayne
wgood is offline
To Wheel lug nut torque spec?
Old 11-04-2015, 10:26 PM
meyerweb
meyerweb's Avatar
I have a PDF of the 2016 manual, and it only has 349 pages and no section numbers (e.g. 8-5). ???? In my 2015 manual, wheel torque is specified in section 12-2.
Now that I look again, those aren't Corvette tire sizes, either. Not sure what manual you're looking at, but it's not a C7 Corvette.
As others have said, page 312 if nt 2016 manual says 100 lb ft.
meyerweb is offline
Old 11-04-2015, 10:28 PM
meyerweb
meyerweb's Avatar
That's not true. The C7 is the first car I've owned with lug not torque specs this high. Maybe 100 ft lb is standard for GM cars, but certainly not every car.
meyerweb is offline
Old 11-04-2015, 11:02 PM
Maxie2U
Maxie2U's Avatar
Glad I check my lug nuts, ALL were below 85 lb ft! Now all are torqued to 100 lb ft
Maxie2U is offline
Quick Reply: Wheel lug nut torque spec?
