I hate Dexos
Old 11-22-2015, 11:20 PM
Tex
Tex's Avatar
Default I hate Dexos
After years of GM recommending only Mobil ! for use in Corvettes and badging the engine compartment accordingly- "Use only Mobil 1", the all powerful C7 is born; and with it an inferior blended oil is substituted. Really? I for one don't buy it and I suspect most others don't either. When I got my '14 home I did an oil change to Mobil 1 and I have had two oil changes done at dealership with of course Mobil 1 with some issue- one service advisor even raised the hood to show me the Dexos on the filler cap. I suggested he pay attention to the words coming out of my mouth, that I don't want your blended oil. I can't wait to a replacement oil fill cap is available so I can remove the last vestiges of Dexos from my car! I hate Dexos
Old 11-22-2015, 11:26 PM
meyerweb
meyerweb's Avatar
You didn't need to replace the factory oil. ALL Corvettes leave Bowling Green with Mobil 1 as the factory fill. And Mobil 1 is the official, approved fill for oil changes and what GM reimburses the dealers for. See:
https://www.corvetteforum.com/forums...-use-only.html
It's unfortunate that so many dealers are uneducated as to what they're supposed to do.
BTW, Dexos isn't an oil, it's a spec that many oils, including Mobil 1, meet. You don't say if you have a dry sump or wet sump motor, but if it's a dry sump Mobil 1 caps are available.
The following 2 users liked this post by meyerweb:
Red C8 of Jax (11-23-2015), Steve_R (11-22-2015)
Old 11-22-2015, 11:27 PM
Kracka
Kracka's Avatar
Received 5,714 Likes on 2,921 Posts
There is a Mobil1 cap available for dry sump cars. I got mine on RockAuto for $13 shipped.
Although it led to quite a bit of confusion on the C7 initially, Dexos is a good thing for consumers as it guarantees a certain quality of oil since approved oils are at least a semi-syn and many are full-synthetic. It costs a little more for "regular" cars, but with it comes even longer extended oil drain intervals.
Old 11-22-2015, 11:53 PM
Steve_R
Support Corvetteforum!
Steve_R's Avatar
Received 3,290 Likes on 1,400 Posts
St. Jude Donor '12-'13-'14-'15-'16-'17
OP obviously doesn't know Mobil1 meets the Dexos spec he hates.
bjhayes
bjhayes's Avatar
Dexos is a spec not a brand of oil.... And Mobil 1 is certified to meet Dexos spec requirements.
Old 11-23-2015, 12:17 AM
MikeLsx
MikeLsx's Avatar
I stoped caring about this stuff. They put mobile 1 or not its going to be just fine.
If you motor blows up, have GM buy you another one
The following 2 users liked this post by MikeLsx:
Bavaria (11-25-2015), Glen e (11-23-2015)
Old 11-23-2015, 12:21 AM
Received 19,299 Likes on 13,972 Posts
'20-'21-'22-'23-'24
All the containers of Mobil 1 I have in my garage state it meets Dexos specs. OP is getting bent out of shape for nothing. Now if the dealer is not using Mobil 1 full synthetic, then question it.
Old 11-23-2015, 06:00 AM
mikez06
mikez06's Avatar
Our Corvette Tech surprised me with a Mobil 1 oil cap at my last Mobil 1 ONLY oil change. Don't really know why GM put in the 'dexos' caps, but yes, Mobil 1 FULL SYNTHETIC is 'dexos' approved.
Old 11-23-2015, 07:51 AM
AORoads
AORoads's Avatar
Received 2,481 Likes on 1,944 Posts
St. Jude Donor '15
"In honor of jpee"
Need to study up on oil, Tex. Things change, and sometimes they can change in just a year. It did.
Old 11-23-2015, 08:00 AM
rrsperry
rrsperry's Avatar
Received 1,412 Likes on 737 Posts
It's like saying I hate ISO 9001...
Steve_R (11-23-2015)
Old 11-23-2015, 08:14 AM
DAFFYDRUNK
DAFFYDRUNK's Avatar
I hate dexos oil too. And if your dealer puts that low quality blended syn in your LT1 it will certainly blow up before you get to the dealer driveway. If dexos was a person I'd like totally for sure not talk to them. I'm over 100% serious.
meyerweb (11-23-2015)
Old 11-23-2015, 08:22 AM
dvilin
dvilin's Avatar
Received 7,923 Likes on 4,809 Posts
Big rant over nothing, amazing how people react due to a lack of knowledge.
Old 11-23-2015, 08:29 AM
gurneyeagle
gurneyeagle's Avatar
Daffy just nailed it!
The only thing worse is when the dealer puts in "Mobile One", messes with my "carbon fiber breaks", or gets a grease stain on my "D bottom" steering wheel.
There are some very unique terms used in this forum.
All kidding aside and apologies to those that I may have offended, the passion here is amazing.
Old 11-23-2015, 08:41 AM
DAFFYDRUNK
DAFFYDRUNK's Avatar
This goofy oil stuff is actually illegal in 21 states. They call it driving while DEXOS'd. It's dangerous because at any moment you might experience failure from the lack of really good oil. Might cause traffic jams and even accidents. This could jeopardize small children, puppies, and even baby Jesus.
gurneyeagle (11-23-2015)
Old 11-23-2015, 09:17 AM
JerryU
E-Ray, 3LZ, ZER, LIFT
JerryU's Avatar
Received 9,624 Likes on 6,628 Posts
Been using Mobil 1 in my cars since 1974 when in solved a problem in my 260Z and modified Corvair. Too bad Mobil and others changed from a man made polyalphaolefin (PAO) base for their synthetic oil to a more highly refined, what some call “dino oil” (simply refined crude) in about 2000. That happened after Mobil brought a complaint on the use of the word synthetic against Castrol who started to call their “more refined oil” synthetic! They lost and Mobil also reverted to a more highly refined conventional oil since it cost about half as much to produce! The market price did drop. If you want to read a good old article that was in Car and Driver here is a link: http://www.caranddriver.com/columns/...mantics-column Fun read.
Part of the reason Mobil lost their case was API (American Petroleum Institute) said testing is better than how the product is made in defining how it performs (IMO, because they had tests!) However GM developed their own tests and like API charge the oil manufactures to put "meets dexos" on their product! In fact for a short time Mobil refused to pay GM and did not put dexos on their products - they do now!
All that said, dexos is a test specification. There are 100+ companies that are “approved” to put in on their product. Some whose names I never heard of! They are all probably fine and there is no oil available in the US that is made mostly with a PAO base as in the past! However I still use Mobil 1 but it’s probably no better than some other oils.
Can’t blame the dealers for buying whatever the cheapest dexos approved oil they can get for their 55 gallon drums! That is what most use in the oil change bays and it’s approved by GM. Some dealers probably know that GM says use Mobil 1 in Vette’s but would rather use their 55 gallon drum pumped oil as they use for all other cars! For those dealers doubt an oil fill cap saying "Mobil 1" makes any difference! But for some Vette owners may make them "feel better!" I'm sure they pay significantly more for quarts of Mobil 1! In fact even Walmart who sells 5 quart jugs of Mobil 1 for ~$5/quart gets ~$8 for single quarts!
FWIW
The following 2 users liked this post by JerryU:
BenCasey (11-23-2015), gurneyeagle (11-23-2015)
Old 11-23-2015, 11:20 AM
rmorin1249
rmorin1249's Avatar
Received 1,738 Likes on 1,174 Posts
St. Jude Donor '15-'16,'18
Just curious, is the Corvette the only GM car that is supposed to get Mobil 1 oil at the dealer? What about the V model Cadillacs?
Old 11-23-2015, 01:25 PM
PegasusCapital
CF Senior Member
PegasusCapital's Avatar
For what it's worth, my 2007 XLR-V called for Mobile 1 and had an oil cap that said "Mobil 1". I'm sure the newer model Vs have the same requirement.
To I hate Dexos
Old 11-23-2015, 02:58 PM
senah
senah's Avatar
dexos
dexron
dex cool
i detect a pattern here
Old 11-23-2015, 03:53 PM
DickieDoo
DickieDoo's Avatar
Ok, I hate ISO 9000/9001 etc... another scam that is somehow supposed to make whatever it is they are peddling, good....
What i really hate is GM engineering not specifically putting on a "Mobil 1 Only" cap on the Corvette, one simple label and all problems are solved!
Old 11-23-2015, 03:55 PM
C6 MoneyPit
C6 MoneyPit's Avatar
St. Jude Donor '06-'07-'10, '15. '22-'23
Originally Posted by senah
dexos
dexron
dex cool
Don't forget Dexy's Midnight Runners.
orwollma (11-23-2015)
Quick Reply: I hate Dexos
