Have you ever wondered?
Paid Senior Member
Have you ever wondered if the octane buttons are just an idiot test to see who will pay more for the same gas?
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
No because that would open up the seller to being charged with theft by deception charges. Not a misdemeanor either. It would be a felony based on volume sold.
Received 3,117 Likes
Finalist 2020 C7 of the Year -- Unmodified
Now that's pushing it and I thought I had a OCD problem when it comes to my Corvette
As penniless teens with no money for gas, we used to visit closed gas stations at night to drain the hoses. The gas from several hoses was enough to get us around for a while. I guess the first customers the next day didn’t get all the gas they paid for.
When you pull into a service station to refuel, the guy in front of you just finished filling up with the lowest octane gas. Now I pull up to the same pump and select 92 octane. How much of the low octane fuel remains in the system and is dispensed before the 92 octane is actually supplied to the nozzle?
triton205 (12-03-2015)
So that also means the next car in line gets their first 0.5 gallons "upgraded" to Premium for free
I'm going to start lining up behind other Corvettes at the pumps, selecting regular and just pumping half a gallon. Then I save $0.20 on each half gallon. Then just drive to the next gas station and wait for another Vette to fill up behind. That's gotta be a good use of my time to save a few bucks :-) :-)
On a serious note, have never thought about it and sure don't care!!!!!
Mark
Mark
E-Ray, 3LZ, ZER, LIFT
Received 9,626 Likes
Received 2,225 Likes
I'll second that no.
#33
Received 19,305 Likes
'20-'21-'22-'23-'24
Never crossed my mind. I have more important things to worry about I guess.
#38
St. Jude Donor '16
To the OP: My business has been selling, installing, and servicing gas pumps for 43 years. I know them inside and out and can answer any questions you have about how they work. The bottom line is that the fuel remaining in the hose on a single-hose, multi-grade dispenser is a negligible amount that will not degrade or enhance the octane rating of the delivery. There is a mixing block at the top of the dispenser just upstream of the hose attachment fitting. This is where the fuel is blended (if the dispenser is blending 87 octane with 93 octane to arrive at the 89 mid-grade octane) or in the case of a non-blender, where each octane grade flows through a dedicated pipe from its meter to the mixing block.
The state department of agriculture in most states is tasked with verifying the accuracy of volume delivered and also octane rating of fuel dispensed from gasoline dispensers. There are standards of performance (U.S. Departmlent of Agriculture, Weights and Measures Division, Handbook 44) that define what is acceptable. There is a nominal volume of fuel that is left between the mixing block and nozzle at the end of the delivery. There is an anti-drain valve in the nozzle to prevent someone from draining the fuel from the hose. In a tyical fuel purchase, the minimal volume of lower or higher octane fuel in the hose does not affect the octane rating of the balance of the fuel delivered.
Hope this helps. PM me with any other questions.
BJ
BJ
#40
Hardly an issue for a car-size gas tank. I've researched this a bit, and found estimates from as little as 1/2 litre (from Shell Canada, IIRC) to 1/3 gallon. Assume the worst case, and you put 15 gallons in.
1/3 gallon out of 15 is 1/45 of the fill, or about 2%. Or look at it this way:
1/3 gallon at 87, 44/3 gallons at 93.
1*87 + 44 * 93 / 45 = 92.8666. And that's worst case. If it's only 1/2 liter, you're getting something like 92.99
This may be a real concern for motorcycles with small tanks, but not Corvettes.
