A8-The 2.73 gears vs 2.42--Really?
Ok I get some of it. The Z51 has the 2.73 and base non has 2.42. That is really close so I wonder how much of a difference does it really mean. For the average non racer, can we really feel the difference? Maybe a slight edge in the 1/4 mile. Reminds me of the C6 A6. The Z51 had 2.73 and base had 2.56. Is it worth it for GM to make 2 different gears?
Moderator
Gear Ratios (M7, A8):
...........................A8....Z51A8.. ...MN7...Z51MN7
First gear............... 4.56 .. 4.56 .. 2.66 .. 2.97
Second gear.............. 2.97 .. 2.97 .. 1.78 .. 2.07
Third gear............... 2.08 .. 2.08 .. 1.30 .. 1.43
Fourth gear.............. 1.69 .. 1.69 .. 1.00 .. 1.00
Fifth gear............... 1.27 .. 1.27 .. 0.74 .. 0.71
Sixth gear............... 1.00 .. 1.00 .. 0.50 .. 0.57
Seventh gear............. 0.85 .. 0.85 .. 0.42 .. 0.48
Eighth gear.............. 0.65 .. 0.65 .. .... .. ....
Reverse.................. 3.82 .. 3.82 .. 2.90 .. 2.90
Axle ratio............... 2.41 .. 2.73 .. 3.42 .. 3.42
Overall ratios:
First gear...............10.99 ..12.45 .. 9.10 ..10.16
Second gear.............. 7.16 .. 8.11 .. 6.09 .. 7.08
Third gear............... 5.01 .. 5.68 .. 4.45 .. 4.89
Fourth gear.............. 4.07 .. 4.61 .. 3.42 .. 3.42
Fifth gear............... 3.06 .. 3.47 .. 2.53 .. 2.43
Sixth gear............... 2.41 .. 2.73 .. 1.71 .. 1.95
Seventh gear............. 2.05 .. 2.32 .. 1.44 .. 1.64
Eighth gear.............. 1.57 .. 1.77 .. .... .. ....
While numerically, it doesn't seem like much, it is an over 13% difference.
Overall ratios:
Received 3,117 Likes
Finalist 2020 C7 of the Year -- Unmodified
base has 2.56 gears I believe so.
Moderator
There are no 2.56 gears:
GU6 Rear axle, 3.42 ratio, limited slip (manual trans base and Z51)
GXB Rear axle, 2.41 ratio, limited slip (auto base only)
GU2 Rear axle, 2.73 ratio, electronic limited-slip, performance (auto Z51 only)
Ignoring Z06 for this discussion.
Moderator
No. eLSD is on all Z51's.
Z51 Performance Package, includes (J55) performance brakes, (J6A) Black-painted calipers, slotted brake rotors, (Z52) dry sump oil system, (FE3) Z51 performance suspension, specific shocks, springs and stabilizer bars, (NPP) performance exhaust, (XFJ) P245/35ZR19 front and P285/30ZR20 rear tires, (Q7S) Silver-painted aluminum, 19" front and 20" rear wheels, performance gear ratios, (G96) Electronic Limited Slip Differential (eLSD), (KNR) rear differential cooler, transmission cooling and an Aero Package
G96 Differential, electronic limited slip, rear
Shadeux (02-04-2017)
In the Pontiac G8 world, swapping out the GT's standard differential (2.92) for that of the standard A6 GXP (3.27) would get you roughly a 0.1 to 0.2 sec improvement in the quarter mile, so I suspect the C7 would see a similar improvement going from the 2.41 to the 2.73. If I'm not mistaking, the Z51 is a tad heavier so the difference might not be as noticeable.
Once hind sight is truly 20/20, I'll guess the A8 base and Z51 will end up being a statistical wash for straight line accelleration. For the Z51, steeper gears are offset by heavier weight and and what I think would be an extra shift in the 1/4 for a bone stock C7. 4th to 5th at ~113ish compared to ~123ish mph? LT1 has a pretty wide torque curve so there's less reason to "keep it in the powerband". Either config is traction limited so no real difference on the short end either.
I don't know much about automobile production but from my internet forum education, it is cheaper for the manufacturer to just produce one part.
According to the 2016 Corvette brochure:
- The Base Stingray A8 has a 2.41 axle ratio and a 0 to 60 MPH time of 4.0 seconds. No quarter mile performance is reported.
- The Z51 Stingray A8 has a 2.73 axle ratio, a 0 to 60 MPH time of 3.7 seconds and quarter mile performance of 11.9 seconds at 119 MPH.
Based on my many years of drag racing experience, the 3/10's of a second ET difference in 0 to 60 MPH performance would carry through to the quarter mile finish line, yielding a quarter mile ET of 12.2 seconds for a Base Stingray. Each 1/10 of a second in quarter mile ET yields a one car length difference at the quarter mile finish line. Hence assuming identical reaction times and hook on starting line launch, a Z51 Stingray would cross the quarter mile finish line three car lengths ahead of a Base Stingray. My estimate is that the performance differential between a Base Stingray with the performance exhaust option and a Z51 Stingray would be between 2/10's and 3/10's of a second in 0 to 60 MPH and quarter mile performance.
FWIW, CarCraft magazine thinks the lighter weight of the base model is worth more in the quarter than the gearing and wider tires of the Z51:
http://www.carsillustrated.com/secre...d-c7-corvette/
