Another Tire Noise thread - Will changing all tires eliminate the "skip"
If I was able to test drive my car before I purchased, I might have been on the fence about buying it at all after discovering the tire "skipping" or rubbing or whatever its called.
The noise and feel is absolutely ridiculous. I've had 10 people ask me already if something is wrong with my car because they can hear it "rubbing".
I've read the posts stating its normal, I know, but I don't have to like it.
Is there ANYWAY to eliminate this? Hopefully by swapping all 4 tires?
Also, I haven't been able to find specific info about what is actually causing the noise. This cold tire stuff is bs in my case because even after a 2 hour drive yesterday and some spirited left turns it will still making the noise while maneuvering around my hotel parking lot.
If the tire swap will do It I might just go ditch these things next week.
thanks
thanks
Received 3,290 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
It hurts absolutely nothing. Why would you worry about it let alone spend hundreds of dollars for new tires to reduce it? If it bothers you that much just don't turn as sharp. I'll never understand all the consternation here about something that's normal and hurts nothing.
Edit: It's mentioned in the Owners Manual. You can google Ackerman steering effect for more info than you could ever read about it. It's pretty silly to buy a high performance car with high performance tires and then get lower performance tires to get rid of something that doesn't matter.
It is more than just tires being cold.
I think it is mainly the result of wide tires and steering geometry.
On sharp slow speed turns, the tires can lay over, causing them to skip instead of roll.
vdavenp802 (01-16-2016)
The only way to eliminate the Ackerman steering problem (tire skipping) would be to add a slip differential like they do on 4WD vehicle which is not practical on a sports car.
So yes, simply avoid low speed shape turn.
Received 1,738 Likes
St. Jude Donor '15-'16,'18
I have all season tires and still get a bit of "skip" especially when it's cold and I'm turning at very low speeds like getting out of a parking space. No big deal. It's normal.
You don't need to understand it. Does that answer your question. Damn his whole C7 section is nothing but you guys who just can't understand this or understand that. And it's not just a cold tire issue or sharp turn issue like everyone keeps reposting constantly. It def happens at not so sharp turns and when the tires are warm as well.
What's silly is a $75k car that sounds like the tires are rubbing the fenders.
My curiosity was whether or not another brand tire in the same performance level would cure the issue. Maybe it was just a tire brand / type Specific issue. Then I read comments like this and I want to slap somebody.
Well excuse me! Your posts here today in this thread and the manual vs auto trans thread paint a very nasty, unflattering image of you.
If you don't want answers don't post questions.
And BTW, I understand perfectly well why the tires "skip." You admitted in your first post that you don't.
Chill out.
Chill out.
AdventurePoser (01-10-2016)
When making a u turn an inner tire has to make a tighter arc than the outside tire. Traditionally a car's steering linkage is designed with Ackerman effect, to turn the inside wheel more sharply than the outside wheel so each follows its correct arc.
In the quest for better handling many modern performance cars have discovered that handling is improved when both wheels stay parallel at all times. With linkage set up this way the angle of both wheels can't exactly match the arc they are trying to follow, the tires have to slip a bit in tight turns to compensate. Some cars like Corvette offer tires that grip really well and don't slide easily - instead they grip until they repeatedly break loose causing a hop/skip/chatter effect.
Much has been written about this characteristic of grippy tires on various performance auto forums - Porsche, Mercedes, and others. Some owners are all about performance while others are more into comfort and refinement. These owners may choose to give up a certain percentage of their cars' superior handling capabilities by installing tires with less grip and more slip.
More like the tire is so wide the inside is turning slower than the outside when describing a circle. Since the inside and outside are connected, something has to give.
Received 1,876 Likes
2020 C8 of the Year Finalist - Unmodified
What you fail to understand or refuse to understand is it PHYSICS. When the radius of a turn is too sharp the outer wheel turns much faster than the inside tires resulting in extreme resistance and binding. The problem is accentuate when the tires are wide (i.e. performance tires) As a result the tire will skip.
Considering the dynamics in play I doubt a different set of tires will change the dynamics.
Received 1,694 Likes
St. Jude Donor '15
If you have a passenger in the car, don't make any turns, just drive straight.
