Programming a C7 key fob
I have acquired a new key fob to replace a lost one for my 2014 convertible. I have attempted, per the manual (2-6), multiple times to program the new fob using a recognized transmitter. Each time I get to step 9, pressing the ENGINE START/STOP button with the new transmitter in the steering column pocket, the DIC never displays READY FOR REMOTE #4 or 5. The DIC continues to display step 7, READY FOR REMOTE #3 or 4 and then times out. I don't want to use the procedure for programming without a recognized transmitter because this procedure will wipe the program in my only good transmitter. Does anyone have an alternative method to program a new key fob? Appreciate your help.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,820 Likes
2015 C7 of the Year Finalist
If you want the new RKE to be #2 and have the memory function, you will need to do the long program and erase the memory of RKE #1 and start over. The First RKE inserted in the long program becomes #1 RKE and the 2nd becomes #2 RKE.
http://forums.corvetteforum.com/c7-g...s-and-rke.html
There is no other option to make #2 RKE. Those instructions in that thread are very precise. Maybe they will help you add your RKE as #3 (no seat/DIC memory function).
Elmer
Elmer
orwollma (10-09-2020)
I thought the OP was saying that it doesn't allow him to finish programming #3, that it times out instead of programming #3.
bdstrak: is this correct?
Elmer
Elmer
The reprogramming of both RKEs is still an option.
Immediately, after getting this far in the programming steps, does the known (old working) fob work correctly? I don't mean hours after, but right away.
Did the new fob come with a key? If so, which one does it look like?
Keep at it, you'll get it.
Elmer
The new, used RKE came with a key like the one on the lift. I have a new, uncut key expected to be delivered tomorrow. I plan to take it and ownership proof to my dealer so it can be sent out to be cut IAW my VIN.
The original RKE is GM #22816266. The new/used RKE is also GM #22816266. Both PNs are confirmed by markings on the inside of the case. Given that, I have to assume they operate on the same frequency. Is there a way to identify it's operating frequency? My new uncut key is GM #25962393.
Sorry to dig up an old post and I may have to start a new thread, but figured I'd just pose here, since I can't find an answer to save my life. It's probably buried under all the "how to set memory seat" posts/google results.
My issue is that, while I know how to set memory seats and my fobs work for starting the car, they don't see to be associated to either # position for memory seats. The easy exit works. When I turn the car off and open the door, it goes to the exit position. When I turn the car on, it doesn't move from the exit position. I just traded a 2016 stingray for a 2016 Z06 and I had no issues in the stingray. Whenever I'd stary the stingray, an info message would pop up and say "you are Driver 1 (or 2, if other fob) for memory position". I get no such message in the Z06, so I think that's the issue (and yes, I have auto memory recall on). Is there a way to set a WORKING fob to have a driver #? Do I have to completely reprogram it?
Remember, the programming is in the car, not the FOB. The car differentiates the FOB and knows which is which when you do the "set" + number thing.
There isn't really a difference in the FOBs. The stuff you set for "1" FOB is retained for that FOB as long as you press "Set" and then the number 1 until you hear a beep. When you set #2 FOB, do the settings you want and then press "Set" and the #2 until you hear a beep. Set each FOB without the other FOB present in the car. As far as messages, I can't help you as I have the 14'. Did you get 2 FOBs with the car? Only 1 FOB and you added a FOB?
First...
Yes. Neither one gives me a "you are Driver X for memory feature" message, and neither one activate set 1 or set 2 (i made them both the same). I have to manually hold the 1 or 2 button to get the seat to go to those positions.
Auto Memory Recall
This feature automatically recalls
the current driver’s previously stored
1 or 2 button positions when
entering the vehicle. See Memory
Seats 0 58.
Select Off or On
Red Ryder (02-19-2018)
Well, the manual memory seat function is working. Are we talking A8 or M7?
It's a manual. And yes, I suppose it works in that it moves back for the easy exit, and if i hold 1 or 2, it does go to those presets, but it's not working in terms of me getting in the car, pressing start, and having the seat go to preset 1 or 2, like it should with auto memory recall turned on.
