A8 Issues
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,822 Likes
2015 C7 of the Year Finalist
Len, honestly, yer confusing the hell out of me!
If you have the A6 or A8 in "Drive" it will shift back and forth when it feels the urge from V8 to V4. If you have the car set to "Manual", it stays in V8.
I think the poster was referring to the V4 mode as the ECO mode, not necessarily having the Mode switch sitting in "ECO". Now if he was referring to the M7, then ECO is the only way to get to the V4 mode.
Right?
Elmer
Right?
Elmer
Right?
Elmer
Right?
Elmer
I guess I was confused by the comment that "Automatics are in Eco all the time", which, of course, is not true.
Updated trans production date
When did they start using the updated A8 trans? Production date....
Really??
From the 2015 Owners Manual page 9-42
"ACTIVE FUEL MANAGEMENT (engine cylinder shouts off) 4-Cylinder Mode
Normal with automatic transmission: The engine uses 8-cylinder mode when accelerating, but changes to 4-cylinder mode when coasting.
With manual transmission: Active Fuel Management only active in ECO mode.
Off in Manual mode with automatic transmission unless in ECO mode."
So where did I go wrong???
Black&White, our resident transmission issues expert, says it was sometime in October or November of 2015 if i remember it right.
So even early 2016's have the unrevised transmission.
Received 3,439 Likes
Don't give black and white a hard time, I went through the A8 battle with GM and finally won and got the trans replaced with the new version and it works great.
Received 3,117 Likes
Finalist 2020 C7 of the Year -- Unmodified
In this instance, when I saw your comment, I'm recalling that when I am driving down the road in Auto, it changes between V4 (ECO) and V8. Therefore (I am thinking, looking at your comment), that the car in most definitely not in ECO mode at all times, since the engine moves from V4 to V8, and V8 to V4, as designed.
My response concerned the comment, "Automatics are in Eco all the time"
I do not disagree with the portion of the manual you provided.
I think we both understand how this actually works. I must have somehow mis-interpreted your comment. Perhaps you can help me with where I went wrong.
Knowing my A8 could grenade one day when I get in the vicinity of 10k miles (which seems to be the sweet spot for some reason) I want to be ready and I need this info to do so.
So you said it was the TC as the root cause, do you have any idea what exactly or close to the changes were on the revised version? A revised TC only?
#36
Lol, actually, he's the first to bring the information (that I know of) to this forum about the revised transmission, which to me is valuable knowledge. So all joking aside, I consider that a valuable contribution, as is the information about the TC being the root cause.
My A8 went south at 600 miles, the new trans was finally installed in Dec of 2015 with the new part number along with a new tcm that was replaced the week before the trans.
#38
The following 2 users liked this post by Black&White:
LB001 (02-01-2016),
Orange Z06 Girl (02-06-2016)
