A8 Issues
#162
Do you or anyone else know what's involved in replacing a TC? I presume it dictates a tranny removal, so how invasive is that? In a C2 and most other RWD cars of that era it was quite easy, but I would bet it isn't in the C7.
Tomorrow I'm going to call the SM at a big Corvette dealership nearby and have a little chat. I'll report what I find out.
#163
[QUOTE=iclick;1591480806]Do you or anyone else know what's involved in replacing a TC? I presume it dictates a tranny removal, so how invasive is that? In a C2 and most other RWD cars of that era it was quite easy, but I would bet it isn't in the C7.
Should be similar to C5 and C6 vettes. same setup since 1997
#164
As an update to my reply #151 above, I followed the same route as I did yesterday but noticed no shuddering at all, and tach oscillation was much less prominent with a total range of perhaps 50rpm. It was more like 100 rpm yesterday, and ambient temps were about the same. Called SM at nearby dealership as I said I would but got voicemail and have not heard back from him. Friday is probably a bad day.
What's more, I got an On-Star report today that said I had issues with the Engine and Transmission System (see attached). I plugged in my code reader which said that no trouble codes were stored in the ECU, but a diagnostic test resulted in the following:
MID $41 TID: $94
O2 Heater Monitor Bank 1, Sensor 1
Min 26816
Max 40920
Current 65520
MID $30 TID: $b3
(no description)
Min 26928
Max 12289
Curr 65520
These don't look like A8 issues but I thought I would report them anyway.
MID $41 TID: $94
Min 26816
Max 40920
Current 65520
MID $30 TID: $b3
(no description)
Min 26928
Max 12289
Curr 65520
#165
MID $41 TID: $94
Min 26816
Max 40920
Current 65520
MID $30 TID: $b3
(no description)
Min 26928
Max 12289
Curr 65520
MID $41 TID: $94
Min 26816
Max 40920
Current 65520
MID $30 TID: $b3
(no description)
Min 26928
Max 12289
Curr 65520
#166
Whatever is wrong it isn't throwing any codes or CELs and the car runs flawlessly, since the weirdness described yesterday anyway. Will probably go to the nearest competent dealer ASAP for a scan and a talk with the SM who didn't call me back today. I called late in the day so I'll cut him some slack and try again on Monday.
#167
I was mostly wondering about the torque tube. Does it need to be re-aligned, and if so what's involved in that? My concern is whether a typical dealer tech can get it back up to original specs.
#169
I was told by a tech that he has had to replace engines because of screwed up transmission repairs. He told us to be sure they checked the crank end play. Of course our dealer couldn't say what ours was but said they checked it. I was kind of bothered when he said his guy has a "better way" of mating it all back up than gm recommends. I'm nervous about it but I've launched it hard and no issues. The tech said listen for a growl coming from motor area. Said it may even take 5000 miles to show up.
#170
Good news (maybe)!
I have a 2015 Z51 A8 and at 6k miles it started shuddering when driving (it could pretty much happen at any speed but was worse at low (30 mph) speeds and gentle driving). At first I was in denial then I thought it must be misfiring slightly (seemed like the most likely thing) and took it to the dealer. They said it wasn't misfiring and what it was doing was "in tolerance" so nothing for them to do... Well a $70k car shouldn't shudder like that when driving down the road.
After a while I realized that if I put it in Manual mode it quit instantly and if I put it back in Automatic mode the shuddering restarted. So for a while I drove it in Manual. I also realized that in Auto mode it was dropping into V4 and in Manual mode it was always in V8. It occurred to me it may be the AFM - felt like the small hiccup you get when it goes from V4 to V8 upon acceleration just that it was doing it over and over again.
I researched devices that prevent the car from going into AFM (V4) mode - several people complained that their GM cars were going V4-V8-V4-V8-V4-V8... all the time while they were driving and it seemed like this is what mine was doing too.
So for $199 I bought a device that plugs into the OBD2 port and disables the AFM. IT CURED THE PROBLEM INSTANTLY!
It does not reflash anything so no warranty issues - unplug it and the problem reappears. Doesn't mean to sat I don't have a Torque Converter issue but the only symptoms I had were the unpleasant shuddering while driving gently.
The bonus side effect of this device is that there is no unpleasant hiccup as it comes out of V4 when you get into the accelerator - it's always ready to go! Can't say I have noticed any real increase in fuel consumption by not being in V4 mode.
#171
[QUOTE=Mr. Jones;1591484482]
Powerglide transmission in a C2 cannot be removed without pulling the engine. Not that simple. Transmission can not be removed by itself as the rear crossmember is not removable.
#172
[QUOTE=JoesC5;1591493248]understood but in a c5 and c6 the diff and trans can be pulled without removing the engine.
#173
The Gun Guy
My 2016 Z51 A8 built August 19, 2015 has very harsh shift when first shifting when driven after start up. Subsequent shifts are ok but first shift is always harsh. My guess is that the torque converter leaks down when the engine is off and the fluid has to repressure before shifts are normal. The 2016 has the auxiliary cooler up front under the front clip and that adds additional fluid that must repressure.
Similar issue with my late June 2015 build. If this is the only issue I can live with it. If it gets worse I'll have them check it out during my first scheduled oil change. I am curious to know if my tranny is the "new" one or if there is actually any difference between the "old" and "new" ones other than part number.
I have a procharger installed so I've been reluctant to take it to the dealer. Not because I'm worried about the warranty, but because I don't want them to screw anything up.
EDIT: Also, I should note that since I have the procharger installed, the AFM is disabled (it can't go into V4 mode at any time). It's possible that my car could exhibit the same problem others have mentioned while driving but if it is indeed fixed by disabling the AFM then I wouldn't know if my car has that problem.
#174
I think I have the same problem. When my engine is "cold" and I shift into drive, there is a delay of about 1-2 full seconds before it actually shifts into drive. If I stay on the brake during that whole time, the whole car violently shakes once when it actually shifts to first gear. It's less noticeable if you let off the brake before it shifts since it can actually go forward like it wants to. It only happens when shifting into drive, reverse has no hiccups. It's more noticeable the colder the engine. While it is more noticeable when it's cold outside, it still happens in 80 degree weather if I don't let it warm up. It seems to be that if the engine is warmed up enough that the tachometer doesn't have the extra yellow warning tics, then it doesn't happen. For example, this morning it was very violent. It was parked in my garage but I only let it run for about 5 minutes since I was running late for work. Temp outside was about 50. I left for lunch two hours after getting to work (I eat early since I don't eat breakfast ) and I let it run for about 5 minutes but since it was almost 80 outside and only sitting for 2 hours it was already warmed up. Didn't do it at lunch. Been going on for a few months now. Got about 7,000 miles.
#175
If you want answers about the A8 transmission and torque converter be sure to cast your vote for this week's "ask Tadge" poll question, A8 Transmission/Torque Converter (full question to Tadge can be read in post#6, link below).
Voting ends February 21st.
https://www.corvetteforum.com/forums...ry-2016-a.html
#176
The Gun Guy
Checked it out in a few spots yesterday and as far as I can tell rpms stay constant. On flat surfaces while on cruise control, I can't notice the line move a single bit. I also recorded it all in the PDR since I knew I couldn't stare at the tach the whole time. That didn't show any movements either.
#177
#178
At least one person who did the fluid/filter change reported that his tach quit oscillating.
#179
At least one person who did the fluid/filter change reported that his tach quit oscillating and the shudder disappeared.
#180
