Waiting for the A8 cooling "kit"?
#121
They told me that the info they got showed up in the computer as applying to my car, which is an A8. If anything the information in their computer is usually behind other sources of information. I guess I will know shortly.
#122
The Upgrade package thru Forum members
Ok, so thanks to the guys here that have actually done the job and a little work on my part, we have an updated parts list and all of the documents needed to do the job. In a few weeks, I will be doing the install myself and will add in some additional pictures and insights (although the guys here have done a fabulous job).
We are developing a template that we will make available electronically or perhaps a physical template for a small cost to cover mailing/copying.
With regards tot he parts purchase, we have worked out a $$ deal that you can take advantage of as a member of this forum. You will need to contact my buddy Jason Kretsch by email at jkretsch@gandrud.com or ask for him at 920.468.3698. He has the entire list, options for you to choose on a few things like the grille and fender ducts. He can help you with any other needs at same time and will give you special pricing.
Again, a super shout out to my adopted friends on the forum that have made this happen.
J
J
Harris (03-22-2017)
#123
Do any of you see a reason why this couldn't be installed on a 2016 Non z51 car? Or has anyone with a base car done the upgrade?
You guys have done an amazing job at documenting the install process and coming up with the required parts list.
#125
If pushed the car would hit 280* trans temp within a lap or two on a high 80s low 90s day.
I would probably have one of my GM mechanic budys install everything and dont really like the Idea of having $2-3K wrapped up in just a trans cooler. I do like the fact that you have used all factory parts in the factory installed manner and it looks bone stock when completed.
#126
Even if you had bought an A8 z51 it would still overheat. One word of caution would be to check and make sure that the base car came with the fan for the trans cooler in the left rear quarter panel. If there is no fan, there is probably no wiring harness. My window sticker says the z51 gets the e-diff and diff cooler in the right rear but does not mention trans cooler or fan so it is worth checking before you get too deep into this.
#127
Im not sure what the best route for me is. I have seen the post on installing the Z06 cooler on an M7 car, using the factory lines. Similar to how the LG cooler is mounted and just bending the lines.
My thinking was that I could get the larger Z06/newz51 cooler with small fan installed on the driver side, and then buy the air duct for the passenger side and install my factory cooler and fan over there. Seen a post that LG was now working on doing this for their new setup. Would save running the lines to the front of the car, and probably something I would feel comfortable with doing myself.
Would also allow me to install the front mounted cooler as an engine coolant radiator, and hopefully help keep the coolant and oil temps down a little bit.
#128
I wanted to check in with the idea that someone will finally hear when a cooling kit would be allowed under warranty assuming a dealer installed approved GM parts. Just read everyone's documentation and would like to get this done when it is finally mainstream if ever.
#129
Still no info if anything is ever going to exist. The computer info for "Auxiliary transmission cooler" the dealer found shows now as updated on April 1st but still doesn't show as available.
#131
Absolutely. Used to reach 275/280 in 15 mins in any air temp. Now it's 215/220 tops for 20-25 mins sessions on track. . Here is a snip of the pdr data above from a track day in 80F temps after the Addition of the mods in this thread.
#132
As Bill and Andy said, this is last year at Watkins Glen With 25 Minute sessions in April About a 70 degree day.
This year at Watkins Glen, 75 degrees 30 minute sessions with Chin.
You can also see due to my driving a little faster and ambient temps being warmer, my water and oil temps are higher but the transmission temps are great.
My last two sessions were only a half hour apart because I went out with the next advanced group.
The only two issue's I had was some Trans fluid coming out the vent(I think Andy had the same issue) and I over heated/wore out my fairly new stock pads. I ordered a set of Carbotech XP8/XP10.
15,000 miles and sixteen track days and I still love this car!
Dave
Dave
#133
Dave I am happy for you! Full long session and no trans temp issues. The fluid out the top of the trans I think is slight overfilling and the fluid is foaming a bit and yes I did have that same small amount of fluid come out the top vent when hot. Roll on! All worth the work as I am sure you will agree.
Dave
Dave
#134
I know that most of us appreciate Tadge but didn't he promise us an approved kit by the end of last year? I pay a pretty good price for an HPDE event only to have to go back to the paddock after 1/3 of the time each session over two days. Do I have to put my warranty at risk to fix this on my own using only the GM selected parts listed here? Can anyone suggest an installer that I can go to for this? Thanks.
#135
As Dave and Andy have said, the addition of the A8 coolers really does the trick. Here is my pdr data from the TrackDaze event at VIR on March 21. Two groups were combined into one HOUR session. After 45 minutes, 59 miles 17 laps and almost a tank of gas I gave up and came in with a big smile on my face. I had my best lap time ever on Lap 15 with the left front tire at 39.5lbs after starting at 26.1lbs. The transmission temp kept climbing but did not get over 244. Oh...and yes I had trans fluid coming out the vent also. Subsequent to this event two friends, Craig and Brian, fabbed up a shield to attach to the X-pipe bracket in front of the Torque Converter access hole. We attached thermo-shield to it and it deflects all the hot air coming from the tunnel and hitting the torque converter housing and melting the rubber plug. At the NCM bash, trans temps never got over 221 and no fluid out the vent.
Here is the pic from VIR
#136
Hey Dave. I would be interested in seeing a picture of the shield you guys came up with. I made a sheild a while back that attaches under the differential that directed cool air to the finned cooler that is now gone and I don't need it. Yours sounds like a helpful setup for thw cooler setup we have now.
#137
Hi Andy
Ok...here are the pics. This is the finished product on my car:
Now here is a sequence of pictures that Craig and Brian put together as they were making this piece. They used a piece of sheet metal....pretty thin stuff and a drill and tap for 6-32 machine screws. These are not in any particular order:
#138
#139
I struggle to identify the part number of this bracket and the bolts in the first post . Can someone help me ?
Regards
Götz
#140
I think the items you are looking for are items 2,3, and 6 from the list on post#1 from Bill. If you go look at post #120, it will help explain and shows the diagram. For Bill the originator of this project and early adopters of this addition like me we bought the whole front baffle and the brackets came with the baffle. But jrider got the part numbers for 2016 and up cars for just the brackets and bolts if that is all you need. The new baffle also gave us the template to cut the hole in your existing baffle. PM me if you need further explanation of the mod. It was the best mod I did for my 2015 and looks factory. I have had zero issues with trans cooling since then.
goec2468 (05-12-2019)
