OnStar email warning
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
So I get this email warning telling me I have 26 psi in my right rear tire. So I walk out to the garage. Check the pressure with my digital hand held. 33 psi. Not bad considering it was 28 degrees out side and the garage isn't heated. The other three were the same too.
NCM Lifetime Member
OnStar is weird
On Star probably checked your cars vitals when you drove it out of the garage and then sent you the message. If you then drove it that would probably explain the rise in tire pressure after you got it back in the garage. I have On Star on all three of our cars and the two in the garage never get an On Star report until I drive them out of the garage into satellite range.
NCM Lifetime Member
Received 19,307 Likes
'20-'21-'22-'23-'24
That is quite a difference if the gauge is accurate. The OnStar reading on my DD is only about 1 psi different than my gauge reads.
What is your dic read out saying it is? Flat or fully inflated?
NCM Lifetime Member
NCM Lifetime Member
All four are spot on 35. It may have been a fluke reading as the car was parked in the garage which is wood frame with windows. Some times sat radio works, some times it doesn't. I don't recall if I'd pulled in or backed in the previous night.
NCM Lifetime Member
Nail in tire
Finally nailed down the problem ............. 1" finishing nail. Dead center of the tire so Discount Tire Of TX was able to fix it. Darn good thing as I still have 6/32" of tread left.
Spooky
If OnStar sent you an email saying you only had 26# in the tire, but at that time the DIC said 35# and your handheld said 33#, how the heck did OnStar detect the nail
NCM Lifetime Member
Good question ................. Magic 8 ball maybe ?
