PDR Update Files: Check your version prior to updating
#81
#83
Updated mine today, which was about as easy an update as could be imagined. Here was my procedure:
- Removed all MP4 files from the SD card (Sony 32gb Class 10 formatted FAT32) and copied the four update files into the root directory (i.e., not into a subdirectory).
- Put ignition in service mode (hold start button for 5 sec.). I did not start engine but connected battery tender to help keep voltage up, which showed 12.5V throughout the process, 12.0V being the minimum spec.
- Inserted card.
- Selected PDR mode from the main menu, it located the files immediately, and asked if I wanted to update the software, which I affirmed.
- It started and showed progress as a percentage. By the time I walked into the house to retrieve the instructions that I had forgotten it was finished, probably around 3-4 minutes. Did not need to repeat the update a second time.
- Once finished, delete the update files from the card or otherwise it'll ask you if you want to update every time you enter PDR mode.
CB
#84
I know the moderators have to follow a GM request, however these moderators should also inform GM that in this case owners of the car do a better job than the dealership.
Time is money GM as the saying goes and YOU (GM) are making all of us loose a lot of it.
It also will contribute to a better relationship between GM and its customers.
This is the age of technology, so please review your mandate and give us the tools to update our cars.
#86
Received 9,512 Likes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
#87
Can someone please pm me the PDR update files. Dealership said they did the update but it still shows old #s. Don't want to take up another half day at the dealership. Thanks
#92
Did mine last night, and it was just as easy as described. I followed the instructions from above except the system wanted to restart and update a second time so I left the SD card in and ran it a second time. The whole process was only about 10 minutes... instead of what could have been a painful few hours at the dealership. Now have the new version with much improved video quality.
#95
Can someone send me the files link please? Just picked up the car and everything is green on the PDR.
#96
The following 2 users liked this post by cheapthrills:
genesis_1086 (06-19-2016),
time2run (06-02-2016)
#98
#99
