Warble sound occasionally
#1321
Off-Topic
I can appreciate your wanting to fix your car but the problems you're dealing with are off-topic having nothing to do with the warble noise. Off topic posts lead an important thread in the wrong direction.
rmorin1249 (03-26-2017)
The following 4 users liked this post by bjones7131:
#1323
Same sound as you
I too have a noise coming from what might be the driveline, or Exhaust. I have a couple of posts on this going now...... ONLY happens when my foot is on the gas pedal, usually lightly.... not flooring it. If I take my foot off the gas and coast, the noise goes away immediately. Does it in ALL driving modes. I have NPP and Mag ride.....
Anyone else ???? I haven't taken it to a dealer yet, as it's a subjective sound.
I meant to add that I too seem to hear it from my LEFT ear..... sounds like it coming from the Left Rear wheel area.
#1324
The post you are citing is nearly a year old. Since that time, Strake's car was bought back by GM as a test bed and helped eventually to determine the cause of the warble noise which is the ring and pinion. I've never heard yet of a ZO6 with the warble noise because it has a completely different diff and ring and pinion set-up.
#1325
Warble
Well it's going in today. First oil change, differential and corsa extreme with x-pipe and black tips. Bye bye NPP. Hope I made the right decision. I was hoping the boxes would fit in the back but had to take everything out. Some pics.
#1326
#1327
Received 2,639 Likes
With all due respect I don't think you've got the same problem. A true "Warbler" is all the time at approx. 1500 rpm's with the drive-line under slight load. It's the same with every problematic base car that has the A8, and 2:41 rear gears. I do hope this affliction doesn't rear it's ugly head in C7's with different gearing, and hope your's is nothing serious.
#1328
#1330
Well if that's the case, then welcome to the s---t storm.
The following 2 users liked this post by Highplains:
Rebel Yell (03-28-2017),
tail_lights (03-28-2017)
#1331
I assume you guys with the Z06 and GS have listened to the youtube video/audio? If your vetts sound like the warble in the youtube then take it in and have the diff. replaced with the new and improved one. If it is the warble this post is based on it will get worse with miles. Good luck!!
#1332
As far as I know, the new diffs coming out are for the base car with the A8. Don't the ZO6 and GS have a completely different, electronic diff with a different ring and pinion?
#1333
U maybe correct Pete, but if it is the same warble, it could still be bad ring and pinion no matter if it's a Z or GS. Either way i would take it in for evaluation and repair. It would be interesting to know if all three models have different diff. set ups aside from the gear ratio. I think the base and Z have same ratio and GS is different, could be wrong!
#1334
Also the sound in the video, sounds the same as mine, except at present its not the same duration in time one to two seconds.
#1335
#1338
interesting, been following this from near the beginning, all a8 s appears, my m7 warbles only when first pulling away, from 700-1100 sometimes, when i shift, i can hear it when into the next gear, but soon as above 1000 gone, hard to replicate sometimes, hate driving at 1000 to hear it. will see how it plays out, but is the same sound as video.
#1339
If indeed you have the warble then you have a ring and pinion slowly but surely going bad. I sure would look into getting it fixed.
#1340
i would, but is hard to replicate, and as i mentioned, is only just above idle or so lift off, for a few seconds. it would be pointless i think taking it in yet. and is still under warranty for a good stretch yet. maybe launch control will kick it up a notch, heh.
