Key Fob Programing
Key Fob Programing
Have a 16 Z06 and lost a key fob. Bought one on the internet and followed instructions in owners manual but no luck getting it to work. Does it have to be programmed only at the dealer?
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,819 Likes
2015 C7 of the Year Finalist
http://forums.corvetteforum.com/c7-g...s-and-rke.html
Elmer
No, you can do it yourself if you have the correct RKE.
Elmer
Elmer
I believe there are 4 different RKEs
M7, M7/convertible
A6-8, A6-8/convertible
You need the correct one of the 4 to program to your car.
http://www.gmpartsdirect.co/auto-par...umber=22779880
22779879 TRANSMITTER W/O REMOTE START $103.50
22779880 TRANSMITTER W/REMOTE START $103.50
That's all the information I have as far as part numbers. A call to the dealer to verify what you need might help.
Elmer
M7, M7/convertible
Elmer
I purchased one on the internet for my Tahoe. It would not program. I took it to the dealer and they could not get it to program either. They never asked where I got it from and replaced it under warranty.
Apparently there are a few RKE's and you have to have the correct replacement for them to work. Mine had a number sticker on it.
Well now I am stuck. Locks work but not Ignition so the car is stock in place . The intrusion botton does nothing any ideas.
M7, M7/convertible
Elmer
M7, M7/convertible
Elmer
Solved the original remote issue. Dealer said intrusion button does not work just leave the hatch up with everything closed and no fob near the car for 12 minutes. By God it works. You may want to add that to your chart. So original fob is working but new one is not.
