A/C Problem?
A/C Problem?
Had my C7 for a month or so. I went to switch the A/C on today going to work. At 70 to 72, it was blowing fairly warm air. When I dropped it to 68 and below, it got that normal A/C "chill" to it.
I'm thinking it may not be calibrated correctly. 70 shouldn't feel "cold" per se, but it was blowing warm/heated feeling air IMO.
Bring it in to get checked?
Mine does the same thing. I usually turn it down low enough to get cold air and it self corrects. Kinda has a mind of its own. Always cools excellent just have to lower the temp for a while.
Not to hijack the thread, but my preferred setting is 69 degrees, but I find that on startup it either blows "full blast" cold or warm air, and takes a while to "settle in". By full blast I dont mean fan speed, I mean temperature.
Is that normal? Most times I either wait it out or like the OP, dial in a different temperature and then dial back to 69 later.
What was the outside temp? I think that has an effect on whether you get cold or warm air.
Conversely, sometimes it pushes heat in similar situations, i.e. outside temp is a bit lower than inside setting, and heat comes on full blast although not needed.
Received 2,639 Likes
Yep, it seems it all depends on the ambient air temp. If it's close to 70 degrees outside give or take some I've found I have to lower the temp on the A/C.
Rebel Yell (04-20-2016)
Its pretty reliable/comfortable in my Pontiac G8 GT DD, I set it at 69 degrees and pretty much never touch it and don't notice the swings I see in my Vette.
The best GM system I ever had was my 1990 C4 coupe. That car pretty much followed the set in temperature. I don't think my body would stand for 69 degrees. I set mine around 74 or higher most of the time.
