What do you think about this panel fit?
Old 04-24-2016, 02:01 PM
mpuzach
mpuzach's Avatar
Received 1,190 Likes on 594 Posts
Default What do you think about this panel fit?
I just noticed this yesterday. Even though I didn't see it before (I've had the car for 18 months), I can't say with certainty that it hasn't always been this way. It seems that the fit should be tighter (which it is on the other side). Thoughts? Is this something that I can adjust myself or will a trip to the dealer be necessary? Thx.
Old 04-24-2016, 02:13 PM
sTz
sTz's Avatar
Received 2,403 Likes on 1,589 Posts
I've seen panels on other Vettes with simiar fitment variances. My rear panels aren't that bad, but not perfect either. Maybe it's just the lighting or shadowing that makes it stand out more to you now... or not. You could simply just push or pull the panel to see if there is any movement, or take it to the dealer, but I would hesitate with the latter. GL
Old 04-24-2016, 02:17 PM
Patches
Support Corvetteforum!
Patches's Avatar
If you take off the seal along the front of the spoiler and loosen a few of the left-most screws in the channel, you should be able to have someone push on the rear fascia while you tighten the screws down to get a better fit.
robertbruce (04-25-2016)
Old 04-24-2016, 02:40 PM
joeybsyc
joeybsyc's Avatar
Mark down your hours and send the labor bill to Bowling Green.
Old 04-24-2016, 02:45 PM
mpuzach
mpuzach's Avatar
Excellent. Thanks, guys.
Patches, I'm just about as mechanically challenged as anyone. How tough is it to remove and replace the seal? Thx.
Old 04-24-2016, 02:47 PM
Patches
Patches's Avatar
Only took me 30 min. to remove the entire rear fascia so performing this correction should not be a big deal.
Old 04-24-2016, 02:53 PM
Patches
Patches's Avatar
You'll only need to release a few of the tabs holding the seal in rather than taking the entire piece out. Theta posted a how-to from the SM. Then you can loosen three or four of the left-side screws under it.
Here's Theta's thread:
https://www.corvetteforum.com/forums...post1587137611
Old 04-24-2016, 02:57 PM
motomanvette
motomanvette's Avatar
If your "challenged" in the mechanical sense, I wouldn't pull off the rear fascia for that. Maybe have the dealer take a peek at it. Good luck.
Landru (04-25-2016)
Old 04-24-2016, 03:01 PM
L8T8
L8T8's Avatar
Increasing the time allocated to QC in Bowling Green will eradicate these ****les. The C7 is at a crossroads and needs a proverbial hand to get to the next level in quality terms.
I've seen worse elsewhere, on cars costing three times as much.
Old 04-24-2016, 03:41 PM
USN SEAL Team Six
USN SEAL Team Six's Avatar
Location: God will judge our enemies. We'll arrange the meeting
And bill it at union pay scale
Old 04-24-2016, 04:48 PM
rkhegler
rkhegler's Avatar
When I visited the Plant in Bowling Green, I observed several quality fit stations where the technician would use a particular gage to measure the fit and trim of the various panels. It appeared they were very diligent about getting it correct. I would take it to your dealer body shop and see if they can make the appropriate adjustments.
Old 04-24-2016, 04:55 PM
TNSQUIRE
TNSQUIRE's Avatar
Mine had a much worse gap. I finally had to have the dealer remove the rear fascia and replace the panel fasteners under that gap. It was especially bad on a hot day.
Old 04-24-2016, 05:06 PM
bbcb
bbcb's Avatar
I suggest the dealer ....you screw it up .. you own it ....take a photo when you drop it off...in the event the dealer scratches or makes it worse in anyway... you are covered ... if you really are particular ..take it to a top rate body shop ...
Old 04-24-2016, 05:13 PM
rcooper
rcooper's Avatar
St. Jude Donor '15
mpuzach, you're the Corvette C7 sales specialist at your dealer and you're asking us about correcting a seam? Don't you trust your dealership? Doesn't bode well for the customers you sell to.
I'd still buy from you if I lived in your area.
You know I'm just funning with you.
Old 04-24-2016, 10:31 PM
Playboy2
Playboy2's Avatar
I have the same thing only in reverse of yours. Looks your uneven at the top and mine is at the bottom, I too just noticed it the other day and couldn't figure out if it's always been like this. The other side is not nearly as bad.
Old 04-25-2016, 12:20 AM
TNSQUIRE
TNSQUIRE's Avatar
That is definitely not right. Looks like a panel issue underneath.
Old 04-25-2016, 12:28 PM
halt00
halt00's Avatar
No indication of a parking lot bump from another car? That is way off.
To What do you think about this panel fit?
Old 04-25-2016, 02:37 PM
proexpert
proexpert's Avatar
What do I think? I think it's typical of the poor build quality for the C7 since the beginning. I also think the paint quality is equally as bad, and this photo shows my point.
Old 04-25-2016, 02:41 PM
dovervold
dovervold's Avatar
Looks exactly like mine, 2014...
Old 04-25-2016, 05:04 PM
DickieDoo
DickieDoo's Avatar
Mine is like that too... i noticed it but not sure if it's enough to complain about but then again... when you spend $87K ( candian price ) on a car, i think the fit should be perfect.
Quick Reply: What do you think about this panel fit?
