1st Gear grinding noise
For the past few days I've been getting a slight grinding noise mostly in 1st gear. I only occurs when i accelerate from a complete stop and happens probably 25% of the time. I've also had a 1 time occurrence when i was in 4th gear and i was going below 25 mph and when i accelerated I heard the grinding sound. I have a 2014 z51 with about 10,000 miles on it. I posted a video of it on youtube. Thanks for all your help
https://www.youtube.com/watch?v=hI9ReDVkC4k
Apologies for this grinding noise concern you’re experiencing with your Corvette. I see that you are seeking advice from the forum, however, feel free to send us a private message if you would like to visit your dealership for an appointment. We would be more than willing to help facilitate that process. Please be sure to include your full contact information, current mileage, VIN, and preferred dealership in your message if you would like our assistance.
Best,
Julie C
Chevrolet Customer Care
I have the same issue on mine, I have been at the dealership about 5 times for the same problem.
I was also contacted by the Chevrolet customer service above, and they said the car is working as designed.
I never thought an 80k + car is designed to make that kind of noises. <br > <br > <br >
VistaVette (03-05-2020)
Wow thats terrible. The sound is getting worse and worse almost every single day. Its actually very embarrassing and the only way for me to avoid the grinding noise is if i give it a lot of gas which probably will cause me to burn out the clutch a lot quicker. ( heres another video from yesterday, you can notice the sound it ALOT worse)
E-Ray, 3LZ, ZER, LIFT
Received 9,625 Likes
https://youtu.be/yoA0k5upDpo
Perhaps more like a clutch pack in a Posi or if you have a Z51 one of the eLSD clutch packs? (What do you have the base car or a Z51/Z06?)
One other possibility is the dual mass flywheel which, early on, several folks reported one of the springs coming loose.
A flywheel problem sound would come from the front as it's attached to the engine, where all gear or clutch pack noise would come from the rear. Sounds like it is getting worse, which is the best thing for a dealer to diagnose!
Just some thoughts, thanks for the video's.
Dual Mass Flywheel (Generic Pic not C7)
Holy crap this is frustrating. I just drove the car around today and the noise is completely gone plus on top of that the clutch feels normal again. When I was having that noise issue the clutch traveled a lot from the time is started to grab the gear until when it actually did engage. Do you guys think the dealer is even going to take a look even if I can't replicate the noise?
Well you have the videos, there is definitely something wrong. Check your clutch fluid for quantity and how clean it looks. At around 5,000 miles my clutch would like chatter on a hard acceleration, I performed the ranger method clutch fluid change and the chattering went away.
For the OP, below is a PDF showing what my clutch fluid looked like on the first replacement and progressively what it looked like after 8 empty/refill with 30 pumps each. That is 240 clutch activations!
The 2014 Owners Manual says change clutch fluid every 2 years. Assume they mean bleed the system. Unfortunately to gain access to the bleed screw the metal bottom tunnel cover, and exhaust pipe and a catalytic converter have to be removed! I figure the Ranger method every year should be similar (if you're not drag racing.) Worked for my C6.
http://netwelding.com/Clutch_Fluid.pdf
Why not have a passenger hold the camera showing your hands and legs, so we can see what you are doing at the time of the grinding? I don't know if you are moving the shift lever, pushing in the clutch, letting it out, or what?
Michael
Michael
TI837 (04-30-2016)
Hi TI837,
Best,
Julie C
Best,
Julie C
Thank you,
Rich Fazio
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
aaaand another 3 year old thread resurrected from the dead.....
Hey guys, new member here. I have a 2017 base Stingray with manual transmission doing the exact same noise as the video in this thread. It’s still under warranty but the first dealership I took it to said a clutch wouldn’t be covered under warranty and wouldn’t even look at the issue without me paying a 220$ diagnostic fee. Can anybody help or advise me please? Thanks
