Went over 4,500 rpm on break in period.
Old 05-02-2016, 11:51 PM
Jmcdude
Support Corvetteforum!
Jmcdude's Avatar
Default Went over 4,500 rpm on break in period.
I picked up my Z51 less than two weeks ago. I was cruising around the other day and I got on it a little too much I guess and when I looked at the tach I saw that I hit about 4800 rpm's and the yellow warning from 3500 -4500 on the tach disappeared . It's and auto and i thought it would upshift earlier but I must gave it a little too much pedal and she didn't shift. If I have an engine problem down the road will GM read the computer and see that I didn't follow the recommended break in procedure and void coverage?
Old 05-02-2016, 11:55 PM
Skidplate
Skidplate's Avatar
You did not void your warranty. The break in procedure is recommended, not mandated.
The following 2 users liked this post by Skidplate:
Jmcdude (05-03-2016), Rebel Yell (05-03-2016)
Old 05-03-2016, 12:23 AM
DCortez
DCortez's Avatar
The key, from what I know, is to not ride your car at those rpms. Hitting won't ruin it, that much I know
Old 05-03-2016, 12:38 AM
Hopper12
Hopper12's Avatar
Received 2,060 Likes on 980 Posts
Rest easy, no problem at all, and enjoy your new C7!
Old 05-03-2016, 12:45 AM
tail_lights
tail_lights's Avatar
Old 05-03-2016, 01:47 AM
TyBoo
TyBoo's Avatar
I have the A6 and mistakenly moved the shift lever all the way down to M a few times early on. It never hit the rev limiter but the RPMs were up there a ways. I had the same concerns as you about the data being stored but talked myself out of that worry. However, the car used nearly a full quart of oil in the first 75% of oil life so then I started worrying about that being related to breaking the break in rules. The second oil fill went 85% without using a drop so now I only worry about normal stuff like putting on enough miles before the end of July to get a third free oil change.
Old 05-03-2016, 03:04 AM
bob53
bob53's Avatar
Despite all of the obligatory verbage of the break-in recommendations from GM, it's actually good for your motor (once up to temp) for moderate throttle and high RPMs, especially if you let the engine brake from the higher RPMs to create negative pressure to help seat the compression rings. Babying the motor in the first 100-200 miles with lots of idling and minimal throttle risks glazing the cylinder walls which can lead to less HP and more oil consumption.
Not quite as easy with an automatic but I suspect you can force this with manual mode.
Old 05-03-2016, 07:06 AM
C7Joy
C7Joy's Avatar
I hit 5000 several times, briefly during breakin. No sweat!
Old 05-03-2016, 07:41 AM
Jmcdude
Jmcdude's Avatar
Thank fellas, that's great to know. It did seem illogical that something like that would void or hamper the warranty, otherwise GM would have simply had a rev limiter in place until she went over 500 miles. And I haven't sat idling for long periods either as don't like wasting fuel. I have also been using the paddle shifters to do some engine breaking to help vary the RPM's and to hear that awesome bellow from the NPP as I pull up to red lights Not exactly babying her either, getting less than 18 mpg per tank
Old 05-03-2016, 07:59 AM
JLargo
JLargo's Avatar
I am guilty as well.
Old 05-03-2016, 08:02 AM
dvilin
dvilin's Avatar
Received 7,918 Likes on 4,804 Posts
No problem as others have stated enjoy it.
Old 05-03-2016, 08:13 AM
Cur
Cur's Avatar
Honestly, I made sure I approached that 'redline' every time I drove it. Break-in is the worst time to baby your call. Run it up and down the RPM bands, and let the engine brake itself. As mentioned that negative pressure is good for it.
Old 05-03-2016, 01:37 PM
Jus Cruisin
Jus Cruisin's Avatar
The men in black from OnStar will be visiting you (OP) soon.
Old 05-03-2016, 01:54 PM
chrsschb
chrsschb's Avatar
Sell it now, your car is going to blow up or implode. Let some other sucker deal with those headaches.
Old 05-03-2016, 02:19 PM
Greg00Coupe
Greg00Coupe's Avatar
Received 1,974 Likes on 1,140 Posts
I'll give you $10K for it since you violated rule #1.
Old 05-03-2016, 02:30 PM
Bill17601
AIR FORCE VETERAN
Bill17601's Avatar
Hey it's your car. It's up to you to follow the recommendations or not. In my opinion they are there for a reason. Some people don't believe it's important. Chevrolet spent good money to put that information in the system. Chevrolet is not known for spending money for no reason at all.
Old 05-03-2016, 02:40 PM
RapidC84B
RapidC84B's Avatar
Received 13,146 Likes on 5,983 Posts
It's trashed. I'll buy it off you for $5,000.
To Went over 4,500 rpm on break in period.
Old 05-03-2016, 02:44 PM
Larry/car
Larry/car's Avatar
Remember your RPMs are always limited until your engine reached operating temperature.
Old 05-03-2016, 03:11 PM
DAFFYDRUNK
DAFFYDRUNK's Avatar
Good thing you didn't hit 5k. I've been told this punches a hole in the universe and life as we know it abruptly ends. At 4800, the rest of us are okay, but some guys that look suspiciously like Gestapo will be swarming your house any minute to ask for your papers.
Last edited by DAFFYDRUNK; 05-03-2016 at 03:13 PM. Reason: They also might look like MIB. Close your garage door immeditaley and hide.
Old 05-03-2016, 03:22 PM
QKSLVRZ
QKSLVRZ's Avatar
What you don't want to do is overheat the rings and take some of the temper out of the metal.
So while YMMV, short bursts of higher rpm's aren't bad, and it's also recommended to use some engine braking to slow down to make sure the rings get oiled. Also bad is high throttle low rpm lugging the engine.
Quick Reply: Went over 4,500 rpm on break in period.
