About when to get a new battery
My C7 is getting long in the tooth *2 and a half years old" 13K miles
Should I be thinking of a new battery any time soon. Have been stuck in the past when my C6 battery went dead.
Wait until it dies, and go to Walmart and get replacement. They have a 3 year warranty. On my C5 because it sat for 6-7 months every year it was almost dead every year. I would take it back and they would give me a new one with a new 3 year warranty. I probably got 8-10 batteries from them all under warranty. So I always had a new or near new battery in it. BTW I questioned their policy and the manager told me as long as it died before the 3 years Id get a new one. No receipt needed. Stupid policy but as long as they offered it I would recommend it.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
Unless you do a lot of short trips (no ability to fully recharge the battery), I'd suggest waiting, too. BTW, how long did your C6 batt. last and did you use a battery "maintainer"?
After many cars and years (both more than I'd like to admit ), I have a rule of thumb that has never let me down (as long as you take steps to ensure that you trickle charge batteries that are not used over the winter, etc.): I replace the battery in any of our cars every 4 years.
Will most batteries last longer? Yes (unless a cell goes bad, etc.)
Is 4 years starting to fall close to the timing when you 'are working on borrowed time? Yes
If you wait until it dies, will it be most at a most inconvenient location and/or time? Absolutely Yes
Is it worth the few extra dollars I might save to stretch it until it dies on me vs. not having to worry about it? No
That's my .02, which is probably .05 more than it's worth.
Zircon (05-09-2016)
I agree that a battery over four years old is pushing the limit. I bough a ACDelco professional grade battery with a 50 month free replacement warranty and got a new one at over three years old, no questions asked. Just told them it was not maintaining 12 plus volts.
I have had so many Delco batteries fail over the years that once the 3 year new cars warranty expires I go buy a Sears Die Hard battery and then I replace it every 3 years too. I have been burned too many times in years past in the middle of nowhere with a dead battery so I try to eliminate that from happening now. Cheap insurance IMO in this Texas heat/cold.
I'd wait til it fails to start that one cold morning or when it is noticeably struggling to power the starter motor.
Walmart is pretty good place to get a replacement warranty wise as they wont try to hassle you, but generally batteries with better warranties cost more and have better cells
Received 3,110 Likes
Finalist 2020 C7 of the Year -- Unmodified
I would only get a factory stock Delco replacement battery for my factory stock C7.
An AC Delco battery will always warn you when it's time to get a replacement. Ignore the warnings at your peril. My C6 battery lasted 5 years.
My C7 battery starts promptly every time I start the car. I'm at 26,000 miles. When it fails to start promptly it'll be time for a new battery.
Old technology, Bad Luck ? maybe.
In 1996 I started buying new cars/trucks.
With 6 new vehicles in the last 20 years, all the Delco OEM batteries never had a problem.
Replaced my 2007 GM truck OEM Delco battery after 5 years with a Delco OEM battery just to be on the safe side.
Always used a Battery Tender Plus on my new 2009 C6 OEM Delco battery and it was still going strong after 7 years when traded it in October 2015.
When it's time, my C7 it will get a Delco OEM replacement.
YMMV and just my experience for what it's worth
Battery life is so variable based upon operating conditions that there really is no hard and fast replacement rule based upon time. Someone who rarely drives their C7, takes mostly short trips, and never uses a battery tender could kill the battery within a year since regular batteries don't respond well to being deeply discharged. Another owner who drives regularly for longer trips could easily get 6 years or more out of a battery. I replaced the 7 year old pair of batteries in my GMC 2500HD diesel pickup last year and although they still operated OK I decided it was time before heading out for a multiple day trip; I think the battery in my diesel powered Deere utility tractor was 8 years old when it showed signs of imminent demise.
Sometimes batteries fail without warning due to a shorted or open cell and this happened to me with a two year old battery a few years ago. I left for work and the car started normally for the 25 mile drive and when I decided to leave the office a couple of hours later the battery was absolutely dead.
My 2016 Z06 goes on a battery tender if it likely won't be driven for 7 or more days.
I have had batteries last as little as 14 months and as much as 8 years between failures - there is no hard and fast rule for a replacement schedule.
On my boats we replace all of the batteries (5 on my large boat, 2 on the small boat) every 3 years, but on the cars I take the position I expect them to last for as long as I plan to own the car.
Received 19,293 Likes
'20-'21-'22-'23-'24
Batteries should last much longer than 2.5 years. My wife's 2009 Cobalt still has he original Delco battery in it and it is going strong.
E-Ray, 3LZ, ZER, LIFT
Received 9,619 Likes
Not so easy to get the proper battery for the C7!
The C7 battery has a large power board and multiple wires that attaches to the positive terminal. That terminal must be recessed so it fits properly as there is only a relatively thin foam insert between it and the rear carpet.
If you have not looked at the battery, suggest you do as it's very easy to tear the carpet! Not mentioned in the Owner's Manual but suggest you remove the bottom clips from the passenger side plastic wheel cover. (Only need to unclip the rear one and pull it out a few inches but the front may also come loose. Both easily reconnected by pressing with the side of your hand.) You can actually unclip with your fingers, it's ~3 inches up from the carpet but a plastic trim tool or screw driver can be used. That allows the carpet to be pulled out without tearing the corner.
I am getting a better than OEM AGM battery. Unfortunately an Optima won't fit, not the proper top terminal configuration to accept the power board. I just called Odyssey directly and although they mentioned a number that "fits" since it took transfers to several folks and the young lady didn't sound positive I then called JEGS (who sells them) and their tech took some time and said their notes say it requires some modification but no mention of what that is!
Have found an AGM at Sears and AutoZone that say it fits. In fact the AutoZone pic looks to have the proper shape AND hold down location. It also has 20+% higher CCA that the OEM.
Much better to get one when on sale (which I am waiting for although it's only ~$175) and while it's still working than "if/when" it fails next winter! Also, if I have a fit problem easily returned!
FWIW, I would not let Walmart etc install the battery unless I pulled the carpet back and uncovered it myself! Your carpet, your choice!
