Low speed brake squeal
I have a 2014 Z51 M7 vert with 10K miles and it has developed a low speed, below 10MPH, brake squeal when coming to a stop. It seems to be coming from the rear. I wouldn't think that a set of rear pads would be toast in 10K the way I drive it, but maybe I am wrong. I did a couple of high speed hard stops and didn't hear or feel anything unusual, just at low speed. Do I take it to my dealer or just order a set of Carbotech pads and be done with the squeal and dust?
I had the same problem with mine (2014 Z51 M7 vert) at around 10k miles also. I did the brake bedding procedure as described in the owners manual it the brake squeal is almost gone now. You should try that before buying any new brake pads.
Supporting Vendor
St. Jude Donor '11,'13
Try spraying the calipers with a garden hose to get the brake dust out. If that does not work I will be happy to set you up with a set of Carbotech 1521.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
E-Ray, 3LZ, ZER, LIFT
Received 9,624 Likes
Lived with cleaning my wheels every ~100 miles for a year! If I didn't the dust was hard to remove. Then I switched to Carbotech 1521 pads - I waited a year too long, they are great! No noise, they stop at least as well and IMO better when cold. Now I clean the brake dust when I wash the car. What dust is there washes right off.
See Adams post above, he has great service!
Thanks for the info. Sounds like it is probably calipers all crudded up with brake dust. I have it in the air now changing the oil, so I will blow out the calipers and try the bedding procedure. Then I will spend some money with Andy and get a set of Carbotechs.
Yeah mine too. I noticed it at about 8000 miles. If I don't drive the car for a day or 2 when i back out and going about 2-5 mph out of the driveway it screeches really loud and its embarrasing because well its a 56k sportscar, it shouldn't sound like a 86 toyota corolla. Anywho once i get moving it goes away and won't come back until i haven't driven it again for a few days. More annoying than anything. Was going to make a post but did research first
