Launch Control on '16 Z51
I am having issues figuring out launch control on my c7. I have a '16 A8 Z51. Everything I have found says that I need to put the car in track, double tap traction control to enter and one of the 5 performance traction control modes, put the car in D or M1, hold the brake, floor the gas, it will rev to about 4k revs and hold there until I release the break.
What's happening though is I hold the break, push the gas and about 2.5 - 3k rpm the rear wheels start spinning and it wants to do a break stand burn out.
What am I doing wrong, or is my launch control broken? I swear it worked 5 months ago last time I used it.
Popular Reply
05-26-2016, 09:02 PM
So 1800 rpm seems wrong, the car will do that if I have TC on normal and it's a very laggy launch. When I've done it before and seen video online it settles the RPMs at around 4000 waiting for the launch.
As far as not holding the break hard enough, let's hope that launch control doesn't rely on the your breaks to hold the car until launch... That means it would fail 100% of the time if your breaks are worn or hot potentially causing a wreck or damage to the break system. I imagine they are using a trans break or something like that to lock the transmission until launch, not letting it apply torque to the breaks and hoping they hold.
Here is a video of me doing it... Notice the throttle position, and the RPM's...
1) Put in track mode
2) Push button 2 times counting One one thousand, two one thousand, pressing on the one and two
3) You will see display tell you that you have entered performance mode, if you don't see that message in the display, it didn't work
4) Hold brake VERY HARD! Like a panic stop hard
5) Floor gas without hesitating
6) A8 will lurch a little then settle down to about 1800 RPM
7) Let off brake and hold on
If you lift the gas at any time, it will revert back to normal driving mode
I am not sure if it works in manual mode shifting, I haven't ever tried, I always use auto
My guess is you aren't pressing the brake hard enough.
p.dargen (05-28-2016)
The A8 holds at just under 2k RPM, the M7 holds a lot higher. So, there isn't much forward push when staging, since the motor is only at 1800 or so RPM, so it isn't hard on your brakes at all. When you take your foot off the brake pedal, and leave the gas floored, that is when the magic happens, and the car accelerates as fast as possible with the least amount of wheelspin it can manage.
https://www.youtube.com/watch?v=juj4hzGJd5Q
When LC is done correctly, is there any wheel spin or slip or audible tire gripping sound?
It feels like my A8 is leaving in 2nd gear. After it gets going its a beast but the initial launch seems a bit delayed from what I'm used to. Shouldn't the computer struggle to keep the car from spinning? Some chirping, something?
Mine works fine when I finely realized:
Hold the brake down really hard
Stomp hard (quickly) on the gas till it's floored. (disregard the slight lurch)
Settles in at about 1800/1900.
I was just letting up on the brake quickly and getting 4.0/4.3 zero to- 60's on the PDR.
A friend of mine (expert racer) told me to try holding the brake with the inside edge of my left foot, on the lower left corner of the brake pedal; then pop my foot off down and left. Got a couple 3.8's and a 3.9. A tenth is a tenth LOL
Here's another video that shows it better. Both on auto and manual. He also talks about the wheel spin.
