Hatch Cleaning
Old 05-28-2016, 05:15 PM
Normgf
Cruising
Normgf's Avatar
Default Hatch Cleaning
Anyone found a good product or method for cleaning the black underside of the hach that doesn't smear?
Old 05-28-2016, 05:23 PM
Curahee
Curahee's Avatar
What do you do to get the underside of your hatch dirty enough to need more than an occasional wipe with a damp cloth?
Last edited by Steve Garrett; 07-26-2016 at 12:11 PM. Reason: No need to re-quote the OP, especially if you're the next person posting.
Old 05-28-2016, 05:30 PM
L8ter
L8ter's Avatar
Damp cloth when I mop out all the water after I wash it.
Old 05-28-2016, 06:01 PM
w0rM
w0rM's Avatar
If you're talking about the glass, make sure you're using a microfiber towel that's clean and hasn't been dried with a fabric softener. Having clean towels is always the key to clean glass.
Don't use Windex. Get a glass cleaner that's made for cars. I like Invisible Glass - which you can pick up almost anywhere.
I also always do windows twice. Once to get it clean, once to get rid of the streaks.
Old 05-28-2016, 06:13 PM
pdpratt
Red Shadow
Support Corvetteforum!
pdpratt's Avatar
Wolfgang Cockpit Trim Sealant 8 oz.
It does a good job and does not make the plastic real shiny.
Product Description
Now you can keep the interior of your car looking and feeling new with a single product that's incredibly quick and simple to apply. Wolfgang Cockpit Trim Sealant is an invisible, advanced synthetic polymer coating that provides a durable coating of protection and beauty to all leather, plastic, vinyl, rubber, wood and metal interior trim! Wolfgang Cockpit Trim Sealant replaces the need for multiple products!
LbulletM (08-01-2017)
Old 05-28-2016, 10:10 PM
Normgf
Cruising
Normgf's Avatar
Primarily water spots and dust. A damp cloth doesn't remove the water spots.
Old 05-28-2016, 11:04 PM
460HP-YLO-JAKT
460HP-YLO-JAKT's Avatar
I have same problem and also had a thread on this. Feedback did not correct anything and still have the water spots. I'm going to discuss with dealer this coming Thursday. I will monitor your thread to see if anyone comers up with a fix.
Old 05-28-2016, 11:53 PM
owc6
owc6's Avatar
Received 4,186 Likes on 2,679 Posts
Recently, there was a guy who had a whole load of bird poo under there. Yes on the underside of the hatch window.
Old 05-29-2016, 12:22 AM
WMark
WMark's Avatar
St. Jude Donor '11
Had the same issue with my '10 GS. Now seeing it develop on my '16. Damp cloth has never worked in six years of trying.
Thanks for asking. I've always wondered...
Old 05-29-2016, 07:11 AM
probono
probono's Avatar
Try some white vinegar on those water spots...
Ken
Old 05-29-2016, 08:26 AM
Red C8 of Jax
Red C8 of Jax's Avatar
Received 1,113 Likes on 753 Posts
For glass cleaning I use Stoner Invisible Glass. Best glass cleaner I have found. Do NOT use Windex!!!!!
Old 05-29-2016, 05:49 PM
carpe dm
carpe dm's Avatar
"Underhood Spray" from www.griotsgarage.com works well and look nice without runs, etc. Some things will desolve and smear the black paint.
Troymeister (08-01-2017)
Old 05-30-2016, 08:17 AM
HDBADDOG55
HDBADDOG55's Avatar
I found that ProtectAll (you can get this at WalMart) works great on the flat black underside of the deck lid. Spray it on a clean dry cloth, then apply it to the flat black, then wipe off with a soft flannel cloth while still wet.You may have to do the underside of the deck lid a couple of times to get the desired results.
Old 07-24-2016, 01:14 PM
Mck1214
1st Gear
Mck1214's Avatar
Default Hatch cleaning
I had the same problem. I tried interior cleaner, detailer, etc. What I found that works very well is a little WD-40 sprayed on a towel, then wipe dry. Looks like new.
Old 07-26-2016, 08:14 AM
Roadrogue
Roadrogue's Avatar
True. Poor Boys interior cleaner did it to mine. A real bummer.
Old 07-26-2016, 09:13 AM
CriticalmassGT
CriticalmassGT's Avatar
There's this stuff that I used to use after I got a new car and the off-gassing from the plastics would fog up the windows. Hard as hell to remove without streaking. It was simply labeled "Orange Cleaner" and was a buck at the dollar store. It made life a lot easier. But it's hard to find now. It came in an aerosol can.
Old 07-26-2016, 10:41 AM
PaulB
PaulB's Avatar
Several years ago I had a Corvette where the interior gases were overwhelming. Constant cloudiness showed up on everything. I cleaned the interior, especially the Glass, every other day and it still looked like I was a heavy smoker and never ever cleaned the Glass. I ended up doing a BBB Arbitration Lemon Law and eventually won. During the proceedings GM called this problem of gases in the interior a by product on hot days of the Leathers, Plastics, Vinyl's and Glues as Vinyl Hazing. During the time I had the car I had the gasses analyzed and they said the only known possibility for a solution was to continue to wash down the interior with a 50/50 solution of Vinegar and Water until the Interior was neutralized. We never got rid of it. Hopefully today there are better products to resolve this type of problem....
Flyingscot (08-01-2017)
To Hatch Cleaning
Old 08-18-2016, 08:40 PM
Normgf
Cruising
Normgf's Avatar
Thanks Mck1214, the WD40 worked way better than anything else I've tried.
Old 08-19-2016, 08:55 AM
2K14C7
2K14C7's Avatar
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
I've been a fan of the 303 Aero Protectant. They now have individual wipes that come in a dispenser. They work great!
AttyVette (08-01-2017)
Old 08-19-2016, 12:50 PM
xwing
xwing's Avatar
I use windshield washer fluid. I put some in a spray bottle and use on all my automotive glass (inside & out). Stronger and works better than Windex. I like Rain-X as better quality: https://www.rainx.com/product/windsh.../#.V7c42U1TGK4
Quick Reply: Hatch Cleaning
