Ron Fellows/Spring Mountain . . . the details
Just got back from 25 - 26 May owner course. Wanted to relay a few details that might have been posted before.
The cars:
All are coupes with competition seats.
All are Z51 or Z06 w/Z07.
Z06 all have the ceramic brakes and stage 3 aero installed, cup tires removed and SS runflats installed.
Some of the Z51 are non-magride, most are magride
Some of the Z51 don't have heads up
All the cars have PDR
The Z51s have cooling rings installed (w/stainless steel safety wire instead of the factory supplied stuff) The leave the rings in all the time.
Cars are running Hawk pad (but I forgot what kind)
Z51 are on stock run-flats
Brake fluid is changed out to DOT4
Trans/Differential is change out to synthetic and changed fairly often
Cars are bought new and staff puts on 1,500 miles before the cars are tracked.
Alignment is not 'xactly track alignment but something that gives best tire wear.
Tire pressure is 27/28 cold
They use steel open lug nuts
There seems to be plenty of autos both Z51 and Z06
More to follow . . .
The cars:
The following 3 users liked this post by juanvaldez:
I don't think so. I think they are running the same front and rear but she (yep, female shop forema . . forewoman) wasn't very specific. Said the were trying to get the tires up to 34 or 35 hot.
more . . .
Not a lot of track time, maybe a couple of hours in four sessions or so, all lead follow with three cars per instructor, cars rotating out after a couple of laps following instructor. Our course was 1.5 miles pretty tight one straight where you might hit 100.
All run in 3rd and 4th.
One ride along with instructor at claimed 75%.
Several parking lot drills, maximum effort stopping, abs stopping, wet stopping, avoidance in wet while on abs, visual scanning drills, etc.
Some track drills that weren't laps, practice braking and down shift before corner, trail (balance) braking, etc.
blueray16 (05-29-2016)
And you can bring a guest with you at no charge. I took my my son with me and he was able to do everything i did but drive. He did get some track time riding with the instructors and was out on the track taking photos. And bring an SD card to record you track time.
The cars:
The cars:
Level 1 seems to still be available as they said when you come back you could either be in level 1 or 2.
She was not very specific about the trans/diff fluid but said it was something from GM.
Interesting info, thanks for sharing. The Dot 4 brake fluid and synthetic fluids for tranny and diff,makes perfect sense to me. I will make those changes before my first track day. I prefer Carbotech to Hawk pads Also appreciate the tire pressure info and will use that as my starting point on my first track day in my new Z51
I've never seen any definitive info on optimum ride height, so when I am there in two weeks, I'll be measuring ride heights at the fender lip. and will adjust mine accordingly.
I'll be there June 12/13
I didn't think to ask about ride height but I suspect it is stock. They use Hawk pads because they are a sponsor.
I didn't see any catch cans.
So I suspect they might be adjusting with the stock bolts to at least achieve some uniformity.
I'll report back on this when I return
The cars:
The cars:
I believe that we were told Hawk HPS. I didn't hear anything about lubricants other than the sighting of empty Mobil1 drums.
The accommodation:
I was staying in C5. C is across the track, through the tunnel when the track is hot. It is on the second floor, garages and on the ground floor. There are two queen size beds, TV with cable, kitchenete, microwave, mini fridge, bar sink, coffee maker with some nice local roast coffee provided. You can stay an extra night for around $100. Do the paper work when you arrive but won't see the room until after class the first day.
You have to be out by 11 am so you will have to pack up before class on the second day.
There are RV hook-ups. Guy said it was $75/day.
Breakfast a 7:45 both days, buffet, eggs, fruit, meat (bacon one day, patty sausage next), coffee, muffin, yogart, fruit plate.
Lunch 12 first day 12:30 second day burger/chicken patty, vegies, cheese, simple dessert lemon bar/brownie, pasta salad, energy bars,
In the classroom sodas, water, snacks like pretzels, nuts, energy bars
