Had oil change-don't think I got Mobil 1
Just got back from my oil change at the dealer and I asked the service writer if they used Mobil 1 in the corvettes and he said they did use Mobil 1. I checked my paperwork and the part number for the oil was 19293002. My last oil change was at another dealer and the part number for the oil was 12345885 which I am sure is Mobil 1. Does anyone know if part number 19293002 is Mobil 1.
Received 1,738 Likes
St. Jude Donor '15-'16,'18
I think you got the generic dexos oil this time. I had mine changed yesterday and the part # was 12345885.
Red C8 of Jax (06-08-2016)
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,821 Likes
2015 C7 of the Year Finalist
This OIL is a genuine OEM GM part #19293002 and carries a factory warranty.
Sounds like Dexos to me.
12345885 is M1.
Elmer
12345885 is M1.
Elmer
Isn't it amazing that cars used to go 250,000 miles on dino oil? Just boggling...
Your engine will run fine either way. I was asked the second oil change if I wanted Mobil 1 for an extra dollar amount. I then asked what they put in the at the first oil change. Informed it was a blend, Dexos. Since I am not going to keep the car forever, Dexos is fine with me.
Per GM, M1 is supposed to be put in the Corvette.
Elmer
To: Chevrolet, Buick, and GMC Dealers
The 2014-2015 Chevrolet Complete Care Program for Corvettes was designed to take into account the preferred Mobil 1 oil choice of many Corvette owners. As a reminder, dealers are required to use Mobil 1 when performing oil changes on ALL 2014-2015 Corvettes through the Chevrolet Complete Care Program. Current reimbursement levels for Corvette are based on Mobil 1 usage. Please remind all personnel that only Mobil 1 should be used. In addition, please refer to GlobalConnect message # G_0000205212 for details on dry sump equipped (Z51, Z52, and Z06) Corvettes.
In the event a customer paid an upcharge for Mobil 1 under the Chevrolet Complete Care Program, customers should be directed to contact Executive CAC at (855) 435-7284 or email helpacustomer@gm.com for reimbursement.
Elmer
The following 2 users liked this post by eboggs_jkvl:
Ramapo (06-09-2016),
It really makes no difference, Dexos or Mobil 1.
The following 2 users liked this post by dvilin:
Red C8 of Jax (06-08-2016),
rmorin1249 (06-08-2016)
The following 2 users liked this post by 1SG_Ret:
Unless you are not changing your oil at least once a year it won't make a difference for normal street driving. If you are tracking your car it does need a heavier weight oil as GM requires. Personally, when I've gotten my second "free" oil change by the dealer I'll be doing my own changes and I will be using Pennzoil Platinum. No slam against Mobil 1 but I think Pennzoil is better. JMHO.
Received 19,305 Likes
'20-'21-'22-'23-'24
If you are still not sure which oil they put in your car, try tasting it. Mobil One is "hoppier." Dexos has more hints of malt.
Just trying to be helpful.
The following 2 users liked this post by AdventurePoser:
B&BVettes (06-27-2016),
SRQStingray (06-09-2016)
Regardless of what's better oil, I think the main issue is that the dealer lied to you. You said you had asked if they use Mobil 1 and they confirmed that, but then put in Dexos..that's the issue, not so much the oil they put in it..
The following 3 users liked this post by mShak2:
Reason #242 I do my own oil changes, and only use dealer mechanics if I am forced to warranty repair something major.
