Z51 vs GS
1/4 mile times should be a bit slower in the GS, just as they were with the C6. Track lap times will likely be lower with the GS, also as with the C6, depending on the driver. Especially for those who opt for the Z07 package - it will be noticeable for sure.
E-Ray, 3LZ, ZER, LIFT
Received 9,619 Likes
Bench racing is fun but real world data is the only way to find out.
Yes, "reported" by GM, but that's likely just marketing hype. They have to find something advantageous to say about it other than just looks. I suppose it is possible that the extra traction could overcome the weight and drag penalty.
However, I think the safe bet is that the cars will be essentially equal, and the outcome will be entirely dependent upon the driver.
As you say need a side by side comparison, GM numbers will certainly favor the newest model. Considering the variability, why shouldn't they publish the best they obtain! They no doubt did the same with the base car.
As I said bench racing is fun but not definitive!
JerryU (06-25-2016)
GS is only 25lbs. Heavier than a Z51 equiped car. I would think the better traction of the wider tires would more than compensate for such a small weight gain.
On the 1/4 mile track I would expect it to come down to driver.
On the road track I would expect the GS to be substantially faster with an equal driver because that aero drag that is there won't hurt in the corners. The bigger brakes should allow for better entry into those corners too.
Lots of Z51 owners would like to think the GS is just a Z51 with a drag and weight penalty, but I doubt that is accurate.
If you add the Z07 package to the GS you lose around 40 Lbs. so then is lighter than a Z51. The GS wide-body will have very little drag effect over a Z51.
JST4PLA (06-24-2016)
The difference will be in the drivers skill level.
^As with most any racing.
Probably more like 20-25 pounds savings. The carbon ceramic rotors will be lighter per corner vs the iron rotors, but the larger CCB calipers weigh more than the smaller calipers used on the iron rotor cars, offsetting some of the weight savings from the rotors.
We're comparing cars(GS and Z51) not drivers. To compare different cars, you use drivers with identical skills (or the same driver). If you are comparing drivers then you use identical cars(or the same car) with different drivers.
CCM
OEM front Caliper= 10.4 lbs
OEM front CCM Disc=13.4 lbs.
OEM front pads= 6.2lbs
Total OEM CCM front corner brake weight= 30.0 lbs.
VS
Iron
OEM front caliper= 10.4 lbs.
OEM front iron disc/hat= 23.8 lbs.
OEM front pads: 6.2lbs
Total OEM Iron front corner brake weight= 40.4 lbs.
JRitt@essex"
"All numbers below are per corner*
CCM
VS
Iron
JRitt@essex"
CCM
VS
Iron
JRitt@essex"
They don't jive with the weights on the CCB's used on the C6 Z07 and ZR1.
On the C6 CCB's the caliper weight was higher on the CCB cars than on the iron brake cars.
It was a quote from JRitt@Essex (they weighed everything to compare to their brakes), as I copied it. You and I had this same exact discussion many weeks ago, which is where I took this information from.
I question the numbers you provided because the ZR1 has the same diameter front carbon ceramic rotors that weigh 16.2 pounds where the numbers you provided show the C7 carbon ceramic rotors weigh 13.4 pounds.
Also the ZR1 front calipers weigh 16.12 pounds and the number you provided show the C7's caliper weighs just 10.4 pounds.
The ZR1 numbers are from shops that weighed the items and posted them on the C6 Z06 section.
https://www.corvetteforum.com/forums...ight-list.html
Received 3,105 Likes
Finalist 2020 C7 of the Year -- Unmodified
I read that the Z07 package is not available on the C7 GS.
Received 9,512 Likes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
