MP3 playback from jump drive
To be able to listen to ripped books on CDs, I have to combine all the ripped MP3 files into one big honkin MP3 file (11 to 12 HOURS long). The problem is if I touch anything such as "Favorites" while the MP3 is playing, I have to start the huge MP3 over again. There doesn't seem to be a way to get back to where it was playing from.
The question is: Is there a way to make the player play from, say, the middle of an MP3 file? You can't move the playback point from the MP3 play display.
Received 1,694 Likes
St. Jude Donor '15
I can't think of any way other than breaking the file up or putting it on an iPod or MP3 player that has controls on it and bypassing the built in screen. Maybe someone else will know some other way with mylink.
Not sure why you'd put them all into one MP3. Why not just load them as the individual MP3s? At least you'd be able to start from the same book.
To answer your question, I don't think there a way you can start in the middle of a file.
You should be OK to leave them in their individual files. They should play in order. I put 8 books (covering same long story) on a thumb drive, each book has 7 or 8 mp3 files and books are to be heard in order and that's the way it works in wife's Nissan, all automatically. I think it'll work the same on your C7.
You can fast forward or reverse using the double arrow buttons below the Infotainment screen or those on the screen. Hold button down while it searches forward or back.
I don't listen to books in my C7 but when I listen to mp3s I can switch to radio or XM and when I go back to mp3s it picks up right where it left off. I use a SD memory chip rather than a thumb drive. It should work the same with either one. My car is a 2015, born 12/23/14. I don't know if the 14s and 16s work exactly the same. Check the Infotainment owner's manual for more information.
I guess one option would be to go into the ripped images and ensure that there is a consistent naming convention among everything. Most audio books are 10-12 CDs with 12+ tracks on each.
The playing MP3 does pick up where it left off but if I do anything when the MP3 is playing such as fast forward or reverse the player goes to the next MP3 file on the drive. Then I have to start over at the beginning. I really would like to be able to touch screen the playbar and have the MP3 playback start from that point. What I have been doing is remaking the honkin' MP3 file but with the removal of the tracks already listened to.
[QUOTE=CP;1592554614]I tried that but as someone who has ripped a large number of audio CDs, I can tell you that sometimes the naming convention on each CD can be completely different from all the others. As a result, there is then no order to the playback. Some CDs I have ripped have had the track names show up as various song titles. There is no consistency in naming CDs or the tracks on those CDs.
I guess one option would be to go into the ripped images and ensure that there is a consistent naming convention among everything. Most audio books are 10-12 CDs with 12+ tracks on each.[/QUOTE
MP3Tag is a good tool for getting the names right. It's free.
http://www.mp3tag.de/en/index.html
Interesting, CP, the OP.
You posted the following:
Thanks for the suggestion but it's not the tags that are the problem. It's the file names that need changed. I need some sort of program that will allow me to append some constant text followed by the file sequence number in the directory. The program would proceed through the list of files in the directory uniquely naming each one.
for example I would provide a constant text of, say, "Rogue Lawyer Disc 01" and the program would rename the first file in the directory "Rogue Lawyer Disc 01 01" and the second file in the directory "Rogue Lawyer Disc 01 02", and so on. Maybe a small Excel VBA program could do this for me.
I took the time to write a reply to explain how to do what you want but you deleted your post by the time I hit Submit, so I deleted mine.
Thanks for wasting my time.
[QUOTE=driver9;1592554755]
I found an Excel VBA macro that will do the trick. Thanks.
[QUOTE=CP;1592560171][QUOTE=driver9;1592554755]
I found an Excel VBA macro that will do the trick. Thanks.[/QUOTE
And in keeping with your bad manners, you didn't bother to post the solution to the problem you asked for help with.
Awesome.
Awesome.
Woodson (07-04-2016)
[QUOTE=driver9;1592560223][QUOTE=CP;1592560171]
Sheesh!
Here ya go:
Option Explicit
'' Purpose : List selected files from a directory
'' Written : 26-Feb-1999 by Andy Wiggins - Byg Software Ltd
' Two versions of this macro are shown here.
' The first version is the modified version which will parse the directories into separate columns
' The second version is the original version.
Sub ListFiles()
Dim vvRes ''Variant to collect result
Dim viLoopCounter% ''For loop counter
Dim CRCol As Integer
Dim i As Integer
Dim nWS As Worksheet
Application.ScreenUpdating = False
On Error GoTo Endit ' this is messy. The macro will add a sheet anyway and then delete it without asking. It works though.
Set nWS = Worksheets.Add
nWS.Cells.Activate
''Set an error trap - gets around a "Cancel" situation
''Clear the target range, column "A"
Cells.Columns(1).ClearContents
''Go to the top left cell
Cells(1, 1).Select
''Show the file open box and get a result
vvRes = Application.GetOpenFilename("The lot, *.*", MultiSelect:=True)
''Loop for each result in the "fileToOpen" result ..
For viLoopCounter = LBound(vvRes) To UBound(vvRes)
'' .. and input to a cell
Cells(viLoopCounter, 1) = vvRes(viLoopCounter)
Next
Columns("A:A").Select
Selection.TextToColumns Destination:=Range("A1"), DataType:=xlDelimited, _
TextQualifier:=xlDoubleQuote, ConsecutiveDelimiter:=False, Tab:=False, _
Semicolon:=False, Comma:=False, Space:=False, other:=True, OtherChar _
:="", FieldInfo:=Array(Array(1, 1), Array(2, 1), Array(3, 1), Array(4, 1), Array(5, _
1)), TrailingMinusNumbers:=True
Cells.Select
Selection.Columns.AutoFit
Do While Range("A1").Value = ""
Columns(1).EntireColumn.Delete
Loop
Range("A1").Select
CRCol = Selection.CurrentRegion.Columns.Count
For i = 1 To CRCol - 2
Next i
Range("A1").EntireRow.Insert
Range("A1").Select
With Selection
.Value = "Folder"
.Font.FontStyle = "Bold"
End With
Range("B1").Select
With Selection
.Value = "Filename"
End With
On Error Resume Next
nWS.Name = Range("A2").Value
GoTo Finish ' the macro has run with no errors
Endit: ' perhaps someone cancelled half-way, but a sheet has been added anyway. The section deletes that sheet.
Application.DisplayAlerts = False
ActiveSheet.Delete
Application.DisplayAlerts = True
Finish:
End Sub
Sub FileNametoExcel()
Dim fnam As Variant
' fnam is an array of files returned from GetOpenFileName
' note that fnam is of type boolean if no array is returned.
' That is, if the user clicks on cancel in the file open dialog box, fnam is set to FALSE
Dim b As Integer 'counter for filname array
Dim b1 As Integer 'counter for finding \ in filename
Dim c As Integer 'extention marker
' format header
Range("A1").Select
ActiveCell.FormulaR1C1 = "Path and Filenames that had been selected to Rename"
Range("A1").Select
With Selection.Font
.Name = "Arial"
.FontStyle = "Bold"
.Size = 10
End With
Columns("A:A").EntireColumn.AutoFit
Range("B1").Select
ActiveCell.FormulaR1C1 = "Input New Filenames Below"
Range("B1").Select
With Selection.Font
.Name = "Arial"
.FontStyle = "Bold"
.Size = 10
End With
Columns("B:B").EntireColumn.AutoFit
' first open a blank sheet and go to top left ActiveWorkbook.Worksheets.Add
fnam = Application.GetOpenFilename("all files (*.*), *.*", 1, _
"Select Files to Fill Range", "Get Data", True)
If TypeName(fnam) = "Boolean" And Not (IsArray(fnam)) Then Exit Sub
'if user hits cancel, then end
For b = 1 To UBound(fnam)
' print out the filename (with path) into first column of new sheet
ActiveSheet.Cells(b + 1, 1) = fnam(b)
Next
End Sub
Sub RenameFile()
Dim z As String
Dim s As String
Dim V As Integer
Dim TotalRow As Integer
TotalRow = ActiveSheet.UsedRange.Rows.Count
For V = 1 To TotalRow
' Get value of each row in columns 1 start at row 2
z = Cells(V + 1, 1).Value
' Get value of each row in columns 2 start at row 2
s = Cells(V + 1, 2).Value
Dim sOldPathName As String
sOldPathName = z
Name sOldPathName As s
Next V
MsgBox "Congratulations! You have successfully renamed all the files"
End Sub
Here ya go:
Option Explicit
Sub ListFiles()
Dim i As Integer
nWS.Cells.Activate
Cells(1, 1).Select
Next
Cells.Select
Loop
Range("A1").Select
Next i
Range("A1").Select
With Selection
.Value = "Folder"
End With
Range("B1").Select
With Selection
.Value = "Filename"
End With
ActiveSheet.Delete
Finish:
End Sub
Dim fnam As Variant
' format header
Range("A1").Select
Range("A1").Select
With Selection.Font
.Name = "Arial"
.FontStyle = "Bold"
.Size = 10
End With
Range("B1").Select
Range("B1").Select
With Selection.Font
.Name = "Arial"
.FontStyle = "Bold"
.Size = 10
End With
Next
End Sub
Sub RenameFile()
Dim z As String
Dim s As String
Dim V As Integer
sOldPathName = z
Next V
End Sub
Corvette Enthusiast
I just use MP3Tag,
All modern infotainment systems use ID3Tags (version 2.3) to decode track order, album, artist, song title.
If your program that is ripping the MP3s to your HD (including Audio Books) isn't doing this, use a different program.
Not using ID3Tags and relying on track titles is foolish. And I have 8500 songs from 600 albums on a 128 GB USB micro drive (two of them actually, one for each car!) so I'm aware of the benefits.
I just use MP3Tag,
For example CD1 may be named:
Rogue Lawyer Disc 1
and then CD2 may be named
The Rogue Lawyer Disc 2 Disc 2
and the resulting MP3 files on Disc 1 would be named
1 1 track 1.mp3
and the resulting MP3 file on Disc 2 would be named
Lawyer201.mp3
There's no way to tell the infotainment system to play the CDs in a specific order or even the tracks in a specific order. The only way to play the entire book is to wait until one CD image is played, and then go search for the next CD image to play. The system will not play 10+ cd images with whacky names that are not related to each other.
Hence I end up merging all the individual ripped MP3 files, regardless of their names and locations into a single 12 hour MP3 file in which I cannot navigate.
When the MP3 is playing there is a playbar showing the progress of the play but you cannot make the system play at a different spot on that MP3 by touching the screen where you want.
I know I should worry about more important things, too.
It's not that it's not using tags, it's the fact that the individual CD's have different names and that the naming convention of the tracks on the CDs is inconsistent.
Rogue Lawyer Disc 1
1 1 track 1.mp3
Lawyer201.mp3
Rogue Lawyer Disc 1
1 1 track 1.mp3
Lawyer201.mp3
You're definitely right about the amount of trouble that the naming issues cause.
But regarding the playbar, on my 2016 I can manipulate the playbar to change the playback position. Is yours a different year and maybe it's a new feature?
Thanks for posting the VBA code.
Corvette Enthusiast
Rogue Lawyer Disc 1
1 1 track 1.mp3
Lawyer201.mp3
Rogue Lawyer Disc 1
1 1 track 1.mp3
Lawyer201.mp3
I have many "double albums" which work just fine.
However worst case, you make an M3U (Playlist) file. Then select that.
Yea, if you rip your songs all into one big MP3 then you need a M3U playlist or like in order to identify the tracks in that file. Not sure if systems will read the play list though. I don't think the stock system on my 2012 would.
