Getting JL audio stealth box installed next Saturday
My local audio shop is installing the JL audio stealth box and an amp next Saturday for only $100 labor. I'll post pics and a review when installed.
Anybody have any reviews on a stock system?
JL Audio makes some amazing speakers. The stealth boxes are expensive but they're worth it. I've never been disappointed with one.
Received 1,694 Likes
St. Jude Donor '15
Nice! I look forward to your review.
I have a 8 inch JL audio in my Wrangler with a 1500w Kenwood amp running it and Polk speakers. It will shake the teeth out of your mouth. First song you need to play is the extended version of Dire Straights Money for nothing. When the guitars kick in hold on!!
That's usually one of the first songs I play at full volume after a new system install. It will definitely let you know if your gains are set right
Are you upgrading the base system or the Bose system with the factory sub?
How did your installer connect between the factory wiring to the amplifier? Did they use JL cleansweeps or just speaker level inputs?
I'm getting the single 10inch and the amp for mine, but I'm not sure about how to connect it to the amp.
