A6 AFM problem.... advice needed
Old 07-15-2016, 10:02 PM
Roadrunner021
4th Gear
Roadrunner021's Avatar
Default A6 AFM problem.... advice needed
My 2014 A6 does not shift properly in any mode from 4 to 8 cylinders around 25-35 MPH in city traffic. When you need to pick up your speed and you apply the gas, the 4 cylinders rev up quite a bit and it still won't go into 8 cylinders unless I punch it slightly (not good in traffic). The dealer says that it's programmed that way but every 2014 A6 owner I speak with says that they don't notice any shifting issues. I am confident that I have a glitch somewhere? Has anyone come across a solution (possibly hardware) that the warranty will cover?
Old 07-15-2016, 11:21 PM
vanlieremead
vanlieremead's Avatar
Also with an A6, 2014 vert. I don't have an issue though. I let the car take care of itself. I stay in sport mode
Roadrunner021 (07-18-2016)
Old 07-15-2016, 11:40 PM
owc6
owc6's Avatar
Received 4,185 Likes on 2,679 Posts
I don't drive in A very often but, when I do, it transfers seamlessly between the modes. All it takes is a touch of throttle and load, and V4 goes bye-bye.
Seems like something is not right, given your narrative. Is there someone in your area (which would be helpful to fill in on your profile) who owns a '14 A6 who could either drive it or ride along to see if it seems normal to them?
Old 07-16-2016, 12:01 PM
Beezvette
Beezvette's Avatar
Here's how i solved that problem. Put the stick in manual mode and use the paddles. AFM will be disabled and you will have fun shifting. if you are going on a long highway trip, put it in drive and curse when you feel the little shudder when it goes into AFM. I paid for 8 cylinders and i like to use them all, although when we drove to Kentucky i used ECO mode and got 31MPG. I have read that the mileage hit for not using AFM is small,maybe 1 or 2 MPG.
Old 07-18-2016, 10:38 AM
Roadrunner021
4th Gear
The dealer has agreed to reload the AFM software to see if this corrects the 4to8 shifting when I put the gas on to accelerate. I was trying to see if we could replace something on the hardware side, but the head man for the service department said he wouldn't know where to begin. With 900 miles left on my warranty, I'll try anything.
Old 07-18-2016, 10:57 AM
ovrebo1
ovrebo1's Avatar
The dealer is going to do everything they can to spend as little time and money on your problem as they can especially if you are that close to the end of your warranty. If it were me and I have done this with cars that have AFM, buy a programmer and turn it off. Also if you are willing to go the extra mile, buy the mechanical parts that delete the AFM ones and install them.
Old 07-18-2016, 11:52 AM
Always Red Dave
Always Red Dave's Avatar
Received 3,078 Likes on 1,729 Posts
Finalist 2020 C7 of the Year -- Unmodified
A A6 C7 with problems.......
Old 07-18-2016, 01:03 PM
jonn127
jonn127's Avatar
http://www.stingrayforums.com/forum/...-pip5185a.html
this should fix it.
The following 2 users liked this post by jonn127:
DickieDoo (07-18-2016), Roadrunner021 (07-19-2016)
Old 07-18-2016, 01:33 PM
DickieDoo
DickieDoo's Avatar
Originally Posted by jonn127
good catch!
Old 07-18-2016, 08:31 PM
Roadrunner021
4th Gear
Thanks for your input. Please provide me what mechanical parts would be needed to replace the AFM ones or maybe where I could find a reference to them.
To A6 AFM problem.... advice needed
Quick Reply: A6 AFM problem.... advice needed
