Anyone running the T1 suspension?
Supporting Vendor
Yes we have used it in our 2014 Stingray track day car and T-1 race car. Very good upgrade that improves feel and handling.
Well worth the money.
Joe
Joe
juanvaldez (07-17-2016)
Supporting Vendor
Takes away a lot of the body roll... I would not say night and day but definitely a positive especially when comnbined with the shocks, bushings and alignment.
Sr.Random input generator
I already installed the T1 sways, which take the roll, but these lower control arms' joints seem to be very tightly in there. Is there any trick to separating these control arms from hubs? It felt like I put too much torque on the GM separator tool, so I backed off.
Are you talking about separating the ball joint from the knuckle? If so, what I usually do is back the nut off the ball joint so it is on the top threads and not touching the knuckle, then I tap down on the nut with a fairly heavy ball-peen hammer. Sometimes it takes a fairly good whack, but sudden force usually works better at loosening stubborn parts with less risk of damaging something.
