Need help
Need help
I have my car on a lift, changing the exhaust. It says i need the automatic transmission in neutral to take the driver side exhaust out. How do i get it in neutral without starting the car???? Thanks in advance
Service Only Mode This power mode is available for service and diagnostics, and to verify the proper operation of the malfunction indicator lamp as may be required for emission inspection purposes. With the vehicle off, and the brake pedal not applied, pressing and holding the button for more than five seconds will place the vehicle in Service Only Mode.
The instruments and audio systems will operate as they do in ON/RUN, but the vehicle will not be able to be driven. The engine will not start in Service Only Mode. Press the button again to turn the vehicle off.
Now you can press the brake and shift into neutral.
cam30era (07-17-2016)
