ACS Composite Installing Aero Components at Corvette at Carlisle 2016
Former Vendor
August is the month where every Corvette Enthusiast plans to head to Corvettes at Carlisle, this event is by far the largest Corvette gathering in the world, boasting more than 5000 Corvettes from each and every year.
Tons of activities are layed out including autocrossing, dyno testing, burn out contest, GM technical clinics, and a full blown parade through the charming downtown Carlisle city center.
The fairground itself is over 80 acres and will showcase a Manufacturer Alley, Installation Alley, and of course a Swap Meet Area.
Be sure to download the 2016 Event Guide at
http://www.carlisleevents.com/carlis...s-Carlisle.pdf
ACS Composite will be attending offering, onsite installations for both C7 and C6 Corvette aero components.
Corvette Carlisle installation
Be sure to visit ACS at Installation Alley, Booth 203-204-205
carlisle corvette map
Installation clinics will be held starting Thursday August 25th, 2016 through Sunday August 28th, 2016. You are welcomed to stop by, and see first hand how we install everything we sell.
Save on shipping and get the parts installed by the guys who make them.
No installation charge on ACS Mud Flaps while all other combinations of any parts are set at 100$ per car. This includes, any Splitters, deflectors, Grills, Rockers, Diffuser Fins, Quarter Ports, and Wickers.
Reservations are recommended as this will ensure the product and timeslot is reserved for you, 514-828-1000 or info@acscomposite.com
See you at at the show!
Will you have the Corvette C6 World Challenge Hoods at Carlisle? These were once called the "ACP World Challenge Hood". Does ACS produce the WC hoods for ACP?
Specifications? There are no specifications for the WC hood on your web site. How much aero downforce is produced as a result of installing the WC hood? How much temperature reduction on average is gained? Also, what is the weight of the WC hood in RTM composite? Lastly, is the WC hood available in carbon fiber?
Thanks and see you at Carlisle!
Former Vendor
It is too late to order painted hoods to be installed at the show since we have run out of painting time prior to the event.
We did at one time produce the hood under license for ACP in RTM, you can reach out to them for the Carbon Fiber Version of the same hood.
In RTM, the hood weights aprox 20 lbs, while retaining the same design elements as the race version, full inner structure with mounting hardware and no hood pins required at any speed.
As for technical performance specifications, I don't have these on hand as they performed the air flow analysis.
See you at Carlisle !
Bad_AX (08-16-2016)
Former Vendor
After talking to a few members we also offer to deliver parts for pickup.
You can pre order parts on our site and pick them up at the show with no shipping charges. Simply use coupon code carlislepickup on acscomposite.com
