Brakes Sticking when Stored Wet, Why?
Rust build-up from the iron. It's not hurting anything and will quickly be swept away when driven again.
Received 8,928 Likes
It happens on all cars with iron rotors and metallic pads. Surely you must have had cars with wheels that exposed the brake system to moisture and experienced this before.
Bill
Bill
^ it's a Z51 thing
Something else for you to complain about, ey "Team Player" *cough*?
Last edited by mikez06; 08-20-2016 at 03:07 PM. Reason: Oops, forgot the essentials...the ... period! ;)
non-z51 has some kind of treated iron rotors that do not rust.
I have had quite a few cars with metallic pads that would stick after a wash if you didnt move it, same if you drove it in the rain then parked it for a few days.
Any new complaints about the .... A8 ?
OH SNAP! """Compass""" just did that, Mr. Team Player/Compass and whatever other name you're using Black & White!
Last edited by mikez06; 08-20-2016 at 04:02 PM. Reason: so many names, so little time ...
GM developed a process called FNC which keeps rotors from rusting:
Quotted from Wardsauto back in 2011:
"General Motors develops a new heat-treatment process for its brake-system rotors that the auto maker expects will save customers’ money, reduce warranty costs and keep expensive wheels looking good. Called Ferretic Nitro-Carburizing, the patented process cooks rotors at 1,040° F (560° C) for a day, bonding nitrogen atoms to the steel rotors to strengthen and harden them."
My 2014 Stingray does not squeal after washing like my 2009 with cross-drilled rotors did.
For what it's worth, every car I have ever owned has had this issue after a wash or the rain.
This is more noticeable (larger brakes/rotors) than, say, my Saturn or my Honda, but they all did it to a certain extent.
Can't speak to the non Z51 brakes and if they are coated or not ferrous.
E-Ray, 3LZ, ZER, LIFT
Received 9,624 Likes
As you note, a drive around the block or just some stop and goes will do the job. I use a micro towel when I get back and pick up any water drops from the mirrors or spoiler etc.
Even when it's raining the rotors are usually hot from stopping. Takes a lot of energy to stop that is converted to heat and rotors take time to cool. Can easily check, just touch a front rotor when you stop, even when it's raining!
Rotors can get over 1000 F in normal driving. You can touch a rotor after you stop and check it out! But be careful
Brake Rotor Temperature
You can touch them if you like to check the temperature, however, I prefer to use infrared pyrometer. Faster, safer, & more accurate on temperature reading.
