Phone Mount Accessory?
I'm curious how that looks with the power cord running down the middle of the screen when you need to charge the phone (ie. if using Waze, etc.)
Lots of threads on this over the last 3 years. Here are a couple:
https://www.corvetteforum.com/forums/...one-mount.html
https://www.corvetteforum.com/forums/...martphone.html
https://www.corvetteforum.com/forums/...need-this.html
I use a long cable that I've run out the side of the center console (using the 12v charge port inside the console), tucked between seat and console, under the floor mat, and up to the phone, which I rotate while charging. It actually looks better mounted horizontally.
St. Jude Donor '09
I don't have a pic, but see posts #38 and #69 in this thread:
https://www.corvetteforum.com/forums...one-mount.html
ssidekickbp (08-20-2016)
I don't have a pic, but see posts #38 and #69 in this thread: https://www.corvetteforum.com/forums...one-mount.html
$20 Kenu Airframe, hands down. https://www.amazon.com/gp/aw/d/B00D901B4W/
Slips on the lip of the power port door and puts the phone at your fingertips. Get a flat 6" USB cord and a flush 12v adapter and plug the phone into the port. The phone will hide the cord. Cleanest install possible.
I also have the ProClip and like it fine. However, after using it, I would prefer it to be much higher up where the vents are. Don't have to look away from the road as much.
Up top would be great if it weren't for the fact that id have cords all over and I like to have things cleaner.
WTB wireless charging!
I built this by using a ProClip mount and Samsung QI car charger. I cut off a large chunk of the qi base and JB Welded it to the proclip. I like it because it will work with any case.
Sorry for the crappy picture.
There is a button on the back and when you press it the arms on the side spring out so it will fit a very wide range of cases. The Qi works great. Keeps the battery fully charged with Waze on the screen constantly.
I have this on all my cars. The best fit is on my C7.
https://www.amazon.com/iMagnet-Cradl...ywords=imagnet
Agreed . . . after trying a dozen or so phone-holder cradles of various designs, I found "nirvana" w/ the mag mounts. Just move your phone in the general vicinity and it grabs it securely. Once you've used one, everything else seems positively archaic.
The C7 is particularly well-suited to the vent clip per my post #20, with no ugly hardware.
