Auto headlamps
Received 3,289 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
I am NOT an expert on HID lights so I searched and read a bit about longevity. Seems newer HID headlights and ballasts should last 6,000-8,000 hours. I found no mention about repeated cycling reducing that. If that's true the 5 minutes or less they're on because of the auto-on feature isn't something to worry about.
The following 2 users liked this post by Steve_R:
Bayshore Vette (03-17-2022),
owc6 (12-11-2016)
I also wish there was a permanent OFF for the auto headlights. Having them cycle ON and OFF, for 5 seconds, everytime I pull out of my garage is taking life off of the HID bulbs. They can only be turned ON just so many times before they fail.
Anybody know where the light sensor is?
I had my C6 for 7 years and 123,000 miles - no bulb failure
I now have had my C7 for two years and 34,000 miles - no bulb failure
In my experience you're worrying about nothing.
HID bulbs do have a long life, but that is based on continuous hours of operation, however there is a significant life factor for turning then on and off. If these bulbs were easy to change, I wouldn't really care...but they are not on the C7.
From Wikipedia :
"End of life : Factors of wear come mostly from on/off cycles versus the total on time. The highest wear occurs when the HID burner is ignited while still hot and before the metallic salts have recrystallized."
And yes, I do keep my cars for a long time...I still have my C5 that I bought in 2001.......
From Wikipedia :
I had to diagnose and repair the Xenon (HID) bulbs in the wife's BMW years ago, and learned that there are three components: the ballast, a starter and a bulb. Not unlike the old fluorescent lights. In order to figure out what went wrong, I swapped parts left-to-right until I found it, and it was the starter. Her car had auto headlights and would come on every time she entered or exited the garage, just like these guys are complaining about.
In the case of these poor C7 owners who will have premature failure, I would suspect that it would be the starter that goes bad. It was something like $70 for the BMW, which means that it should be at least half that for the Chevy.
Natch, diagnosing it is the hard part. The dealers generally don't bother, and instead recommend swapping out the entire $1000 headlight assembly.
But hey, if worrying about a car's shortened headlight lifespan is your biggest concern these days, then I want your life.
Steve_R (12-12-2016)
Why is this "Big pain"? The lights turn off automatically as well.
It is a bit of unnecessary wear however.
Woodson (03-19-2022)
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,820 Likes
2015 C7 of the Year Finalist
Received 2,051 Likes
St. Jude Donor '13
When I start our C7 in the garage, I twist the headlight switch to the Off position just before hitting Start. After it starts, I release the switch and the lights stay off.
After I back out of the garage, twist the switch again and the daytime running lights come on.
When returning to the garage, twist them Off just before entering.
The C6 will tell you if your lights are Off when they should be on, but the C7 deleted that in another "WTF were they thinking?" move.
Received 1,499 Likes
Here's how you fix it...
take a dremel and carefully open up the back of the switch. Once it's open you will see the spring that holds the switch in the "auto" position. Remove or disable the spring, close up the switch with an adhesive and install it in the dash. YOU'RE DONE!!
By disabling the spring your switch will now stay in the "off" position. You now have totally manual lights again.
if you want, you can wire up the hockey stick lights and make those manual as well. Off and on anytime you want.
I did this on my supersport and it works like a charm. Once it warms up the C7 will get this free mod too.
#33
St. Jude Donor '13
Long ago, someone stated that US cars must have a way to manually turn off the headlights, it was something to do with military bases or blackouts.
I'm not sure if that's really true.
#34
Interesting, thanks. Once you go into gear and after the lights come on, can you twist the switch again and make them go out at that point?
#35
Received 19,292 Likes
'20-'21-'22-'23-'24
I too have not really given this much thought. I start the car and drive away - if it is daylight, I do not really notice the lights are on since I back into my garage and when the door opens the lights are not noticable. If it is dark, the lights are needed anyway.
miami08VETTE (03-26-2022)
#36
#37
St. Jude Donor '13
Headlight repairs can be expensive and inconvenient.
I'm waiting for someone to conduct a double blind controlled study on whether my technique actually extends the headlight life.
Until the study is peer reviewed and published, I'll just turn them Off in the garage and back to Auto after I exit.
Some people wire a small spotlight into their garage door opener, aimed to shine on the headlight sensor. Sometimes that's enough to keep the lights out in the garage, sometimes the lights come on as soon as you back out of the spotlight beam. That would also be a nice topic for further study.
#38
#39
St. Jude Donor '13
With lots of electronics, the on-off cycles are just as important as the actual run time.
When somebody does the controlled study we've discussed, then perhaps we'll know.
After doing it a few times, the "twist off and hold before starting" thing becomes as automatic as fastening the seat belt is for me, and a lot easier.
#40
I usually leave the seatbelt locked if there are a lot of "in and out". In my case, getting the wife to buy into that and executing it perfectly wouldn't be worth the teaching aggravation. Also, I am a big fan of "set it and forget it". Wife's 2010 MB has 100K and autohead lights. Self leveling and probably similar construction bulb. I don't hear many people grumbling about how often their bulb fails either.
Do you think the switch has as good a life as the bulb considering you fiddle with it a couple times a trip? Like I said, I can get the bulb in 10 years time. I can't be sure GM won't "obsolete" the switch now that the C7 is done and we are in year 3 of the C8 run.
