Build sheet
Build sheet
I recently purchased a 2014, 3LT Stingray. Is there any way that I could retrieve the build sheet and find out how many have been made? Thanks for your help.
JACK2012
JACK2012
Received 1,298 Likes
Not quite sure what you are asking...
Build sheets can be purchased from the Corvette museum. Your list of option codes is on a sticker under the rear carpet above the rear fuse block and battery.
2014 production stats are at:
(click on Production Stats):
http://www.corvettemuseum.org/learn/...orvette-specs/
Ron
Ron
Received 19,289 Likes
'20-'21-'22-'23-'24
If you do get a copy of the build sheet from the Corvette Museum, consider becoming a member at the same time. A good organization to belong to.
The NCM advertising for the build sheet repros they sell is a little deceptive in that it contains this line (highlighting added):
Most of the info on the build sheet I got is pretty easy to figure out but there are some entries that still puzzle me. I posted a picture of my build sheet a while back asking if anyone could decipher it and got no response so I guess it is a mystery to all.
I bought the laminated window sticker and build sheet combo from the museum and although it was a little spendy (ninety bucks I think) it is cool to have.
Here is a link to the page at the NCM site.
The Build Sheet, often considered “the holy grail” to many folks is a cool item to find. It is often the only means of verifying exactly what options came with your particular car, and helps you determine how many Corvettes were produced exactly like yours.
JACK2012 (09-18-2016)
Build sheet
Thanks for your help.[/B]
It's not possible to determine the number of Corvettes built with groups of options. The only data that is available is production figures for individual models and RPO codes. In other words, it's easy to find out how many black Stingray coupes were built and how many coupes were built with red brake calipers but it's not possible to determine the number of black coupes that were built with red calipers.
